WatchFace: Digic Watch
https://apps.garmin.com/en-US/apps/d021d6e7-22d3-49e3-a626-4f687f6d1ddd
Settings Features (https://forums.garmin.com/showthread.php?332843-How-to-App-Settings):
- Layout: activity, sunrise/sunset, data;
- Time in UTC setting, shows main time and date in UTC if turned on;
- Background color (black/white), label color, value color, time color;
- Row 1 fields: month, date, day;
- Row 2-4 fields: phone (bluetooth), battery, alarm, notifications (msg), distance (m, km, ft, mi), steps, steps goal, calories (kCal), latitude, longitude, altitude (m, km, ft, mi), training effect, sunrise, sunset, move bar, seconds, UTC time, local time, time till next sun event (sunrise/sunset), week number;
- Activity layout: distance, steps and calories, steps graph for last 7 days and today (left to right);
- Sunrise/sunset layout: sunrise and sunset time on the timeline based on latest position available. Use "Row 4: Middle Field" to change field below the bar;
- Data layout: 4 rows of fields;
IMPORTANT: latitude, longitude, altitude and training effect values are based on last activity, hence please turn GPS on until green status.
Feel free to join the discussion: https://forums.garmin.com/showthread.php?340009-WatchFace-Digic-Watch&p=784765
FB: https://www.facebook.com/yurkevich.vladimir
Thanks for using it! Please don't forget to leave review.
Changelog:
v.2.0.0:
- Added support of Forerunner® 230, Forerunner® 235, Forerunner® 630, Forerunner® 920XT, ForeAthlete® 235J, ForeAthlete® 920XTJ, epix™, vívoactive®, with either 3 or 4 rows fixed layout that fits the screen
v.1.1.22:
- ISO week number field added: https://en.wikipedia.org/wiki/ISO_week_date
v.1.1.21:
- Fixed issue with 12:00 AM hours.
v.1.1.20:
- Very bottom field in Sunrise/sunset layout is now using new "Row 4: Middle Field" to not interfere with already set up layouts, please use it;
v.1.1.19:
- Fields added: UTC time, local time, time till next sun event (sunrise/sunset);
- Very bottom field in Sunrise/sunset layout is now configurable and using "Row 4: Left Field";
- "Time in UTC" setting added, shows main time and date in UTC if turned on;
v.1.1.18:
- fēnix™ 3 HR support added
v.1.1.17:
- Settings issue fix
v.1.1.16:
- Max speed field removed because it doesn't have any data on watch faces.
- Fields added: move bar, seconds, time zone, altitude (km, ft, mi)
v.1.1.15:
- Distance kilometers and miles fix
- Settings fixes
v.1.1.3:
- IQ SDK v.1.2.3
- Data layout added (4 rows)
- New fields added: distance (kilometers), distance (feet), distance (miles), steps goal, latitude, longitude, altitude (meters), max speed (km/h), training effect, sunrise, sunset
v.1.1.1:
- Added background color (black/white) setting
v.1.1.0:
- Bluetooth renamed to Phone, hence Battery is back again to the middle by default
- Notifications setting removed
- Layouts added: activity history (default) and sunrise/sunset (BETA)
- Sunrise/sunset layout (BETA): shows sunrise and sunset time on the timeline based on latest position available, time till sunrise/sunset and current time on the timeline.
- Fields settings added. Row 1 fields: month, date, day. Row 2 fields: phone (bluetooth), battery, alarm, notifications (msg)
v.1.0.5:
- Mobile devices settings issue resolved
v.1.0.4:
- Settings added: label color, value color, time color, show/hide notifications
v.1.0.3:
- Language fixes
v.1.0.1:
- Small fonts refinements
- Attempt to fix missing characters on other languages
v.1.0.0:
- Main release
Discussion. Suggestions? Bugs?
    White Face Issue
    From the screenshots, this looks like the best watch face out there. But unfortunately, 1.1.15 does not work on my D2 Bravo (2.70), every time I try to use the watch face, i get a blank white face for awhile, until it defaults to the OEM watch face.
    Hi there, firstly, thanks for this watch face....it is the first one that I want to use consistently! However, I have found a few anomalies in how it handles 12/24/military time. It'll be easier to show each and explain what I mean (click links)....
    12Hr Setting:
    1) As per Garmin specs, there shouldn't be a leading zero. The time should read 6:35pm
    2) In the 12hr setting, the sunrise and sunset times don't show am/pm indication and shouldn't have a leading zero.
    24Hr Setting:
    1) In 24Hr time, the sunrise time is a full 12hrs out - it should read 05:17
    2) In 24hr time, the sunset time isn't rolling over correctly at midnight and is a full 12hrs out - showing 29:17 instead of 17:17.
    Military time:
    1) Military time should have the leading zero, but is 24hrs format. It should read 18:35, not 06:35pm
    2) Sunrise time is correct and is in the correct format but sunset time should read 17:17
    Thanks again for an excellent watch face!
  • I love the look of this watch face but have a request: would it be possible to make the number of data fields configurable? Thing is I can't read the data fields because they are too small. Maybe there could be an option for less data fields so that they can be larger in size. I'm interested in having: time (of course), battery level, date (day / month is sufficient), number of steps. These would easily fit on two data field lines.
  • First a big thank you for this nice watchface.
    Since some days, don't know exactly when it started, I have problems with adjusting the settings from Connect Mobile.
    When I want to adjust some settings, CGM shows the correct values from the watch. But when I change one value and save it to the watch, all the remaining values, which I didn't change at this moment, are reset to the standard values. Change of settings from the PC works flawless.
    The watch is on 6.72beta, the installed watchface is 1.1.15-upd, CGM is 3.3.
    Updated my Fenix3 to 6.80 this morning, now my history only shows 1 day when it previously showed a week.
    Is this a feature or a bug? Can I change it back to a week?
    Thanks, my favourite watchface by the way!
  • Updated to v6.80.
    Still can't set background to white.
    I see only one activity bar and not full week.
    Can't change the second row settings. Whatever I set it's always default phone-battery-alarm.
  • Updated my Fenix3 to 6.80 this morning, now my history only shows 1 day when it previously showed a week.
    Updated to v6.80.
    I think that updating to 6.8v may have reset the Steps History in the watch itself.
    And that it may not be a bug or an issue, but just need to give it a few days to rebuild with new steps info.
    I have a felling that it will show a new bar for every day until 1 week has past.
    At least that's what I'm thinking!!!
    Pep
    Pep
    i think you're correct there, i now have 2 days worth
    Problem after firmware update
    Hello Vladimir
    very nice watch face I like it very much as good nicely done overview. Yesterday after firmware update (6.8) nice 7 column activity display turn into one column among the screen. Fenix 3
    Do you have any suggestion
    Jacek
  • Hello Vladimir
    Jacek
    Look at the 2 threads above.
    The update reseted the history on the watch itself.
    I now have 3 bars after 3 days.
    After 1 week it will all be back to normal. Not a watch face problem.
    Pep
