Watchface: Digital for TactixD and Digital for TactixD v2 Beta
This is forum to streamline questions processing, feature requests, bug reporting and general discussion regarding
Digital for TactixD face: https://apps.garmin.com/en-US/apps/d4fbcc93-5e5e-4030-8278-2bd8463921db
Digital for TactixD v2 Beta: apps.garmin.com/.../15c35159-bae3-4c12-8539-5305ccd1b933
Idea behind this face is that the best face is the one which is set exactly as i want it.
*** IMPORTANT: Always include your email if you are contacting me using Contact Developer form. Without it i cannot contact you back as form will come with [email protected] as a sender address.
Q&A:
Why there are so many settings available? It is hard to navigate through them:
Sending watchface user defined parameters such as color, font and screen placement through app settings seems to be the only available option at this moment. Amount of settings is a tax for having many objects available. During time i've found out  there are also problems and limitations coming with amount of settings, therefore version 2 is being in development where at least some of the fields configuration will be simplified.
Why are my settings changes not reflected on WatchFace ?
It seems this issue is tied to Garmin CIQ app which is not able handle huge amount of settings properly. When settings are done through Android/iOS Garmin Mobile app all should work as expected.
Will be there Weather details available ?
Yes, weather is in progress and will be included in v2 version. Currently testing various weather providers APIs and fighting with best details visualization on the screen.
Why is my language not supported i see only squares instead of characters ?
During short life time of this face 26 custom fonts have been already requested and implemented. Fonts consume a lot of available resources, therefore characters are limited to the absolute minimum => english characters and numbers only. Languages with 'special' characters such as czech, russian, japanese etc. cannot be supported until more resources will be available to watch faces. Toggle button "Force English Day/Month Name" to force most exposed fields to english has been implemented instead.
Will more features be implemented ?
Yes, i am adding more features based on incoming requests. Priority is usually set by amount of requests.
  • hello could you post the settings of this wf? i am curenttly lost liek two hours on traing to set it up. yours look amazing.
  • Hi I love this watch face. Could you please look into the sunrise and sunset settings as they don't appear to be correct. Also is there any chance of ever adding a compass. That would be perfect for me and I'd certainly buy you a beer or 2.
  • I have a compass if I hold down start/stop. Top right button.
  • Unfortunately, watchface have 1minute refresh rate, if we exclude fact garmin does not allow face to access sensors directly, 1minute refresh compass in face does not make sense. thats why there is a garmin one.
    With regards to sunset/sunrise, as in Q&A which most of the users clearly do not bother to read,  it is the same like any other watch with customizable position settings, you need to get valid GPS fix first. Without it your watchface does not know where you are and refers to the default location in settings which is Central Europe until you change it.
    In detail, having proper sun event times for your location, it is same like with other watch faces which allow custom position modification. You need to tell to the watchface what is your location first so it can calculate proper times. Best is to get valid GPS fix of your current location (start any activity with GPS and wait till GPS fix is received).
    However valid fix is usually available in the newer garmin watch for short period of time. Therefore further behavior depends on how do you have set "Use default position if Activity GPS not available"
    "Use default position if Activity GPS not available" = OFF
    - Watchface will store last valid fix to the memory and will use it in case there is currently no valid fix available in GPS. What coordinates are being used for calculation you can check by temporarily enabling Latitude and Longitude fields. ( my Tactix 7 from time to time provides valid GPS fix on coordinates Lat=0 and Lon=0, i assume it is a Garmin bug, getting new valid fix by starting outdoor activity usually solves it).
    "Use default position if Activity GPS not available" = ON
    - Watchface will forget last GPS fix at the same moment as watch and will use pre-configured default coordinates from settings instead. When you install this face, default location points to Brno, Czech Republic (Lat=49.195061, Lon= 16.606836). You can change it to your preferred one using Default Latitude and Default Longitude settings.
    Until you switch on "Remove +1 . : in Sun Events" settings, there will also be an indicator showing what coordinates are used.
    Indicators are as follows:
    no indicator - current in watch available valid fix from GPS is used
    '.' - Coordinates stored in watchface memory from last valid fix used
    ':' - Coordinates from default Lat/Lon settings are used
    '+1' - Sun event is next day
    '-1' - Sun event was yesterday
  • Hello tomulli,
    do you think Is possibile to fix the weather icon that show always cloudy ?
    Thanks
  • Great info, thanks for sharing. Interesting about limited access to sensors but it makes sense from a battery pov.
    I see the watchface has been updated to support more non-amoled watches. Would it be possible to support the 965 at all please?
  • Hi, !
    What are the names of these fonts on the WF? I find some similar ones in the Internet, but none of them are as cool looking as yours.
  • Custom/homemade bitmap fonts.
  • When will it support amoled watches??
