If you have any suggestions or problems please post it here.
Download:
https://apps.garmin.com/pl-PL/apps/4db3d6ae-569b-4435-a7a2-67a2978c04f0
Download:
Hi there. I would like to thank you for your work and could you please add one more thing in there. I need a weather information so I will appreciate it. Thanks one more time. Best regards
I also would like to have the current temperature as an option to display.
Hi, how can i put colon between the date?
Hi! Great watch face. Currently I am having issues with my screen blinking/flickering when the watch is dimmed and wrist gesture is activated. Had my watch sent to Garmin to change the screen which did not solve the issue, just got a recertified unit as a replacement now and the issue is still there.
Tried changing the watch face now to another, and the issue disappeared.
Are there a solution to this? Would prefer to keep this watch face over others.
My watch is an epic gen 2.
I had the same issue when I recently purchased the new S70 (my S62 was fine) and inquired with Garmin tech support. They concluded it was the 3rd party watch face. I played around with settings and the issue disappeared when I turned off "always on" display.
Love the face TomekCzer; have used it exclusively for years. Thanks for taking the time to build and support these faces.
Hi Tomek,
Currently it is not possible to Set temp., windspeed and bearing on fenix 7 pro, the value on the screen remain empty.
Temp. Only is possible.
Can you double check that.
Thanks
Christian
