If you have any suggestions or problems please post it here.
Download:
https://apps.garmin.com/pl-PL/apps/4db3d6ae-569b-4435-a7a2-67a2978c04f0
Download:
Hi there. I would like to thank you for your work and could you please add one more thing in there. I need a weather information so I will appreciate it. Thanks one more time. Best regards
I also would like to have the current temperature as an option to display.
Hi, how can i put colon between the date?
In the next updates I want to make some changes in battery status display and I think it's good idea if battery icon will be red when less than 20%.
I love that I can customize this watch face! One issue though - I changed the settings to show the do not disturb icon, but when I turn do not disturb on using my watch, the icon doesn't appear. Am I doing something wrong? Thanks!
What model do you have?
Fr45 is 1.4.x sdk device and dnd icon is supported since 2.1.0 sdk.
I also have 1.4.x device (tactix bravo). It's no possible to show dnd icon in our devices. You can turn on dnd mode in the watch but icon won't show on Simple TDB watch face. It will show on fenix 5 for exaple.
I have the same problem like xinpengW 3 months ago
However I had small issue with Sun event. After GPS located my position it will show but will disappear later. I guess this is because the previous location was not store in your code, when there is not activity i. e. No GPS location "null" the watch face just shows - -. If you could let the code store the previous location until there is a update.
GPS-Fix all is ok. About 30min later shows -- . Hours later without GPS fix Sun event is displayed and then again not. And so on. FR945 SW 5.50. Pls fix it or maybe workaround manual coordinates input.
