Data Field: Dozen Run Fields
Dozen Run, Swim, Paddle and Cycle Data Fields
After others are forcing you to pay for these applications, so I decided to make a great data field(s) and then keep them free. I'm a Software engineer, sponsored runner and run coach, I combined my engineering and running knowledge to bring you these streamline applications.
I put thousands of hours of bench and field testing these simple applications. So, consider a small donation.
Small donations (help keep my effort going) paypal.me/fbbbrown
Install Instructions:
This Data field needs to be added to the (specific) app within your watch to view.
This is a data field not an application and needs to be added to a single data screen within an application.
a.) Goto settings,apps,run,data screen,screen 1
b.)Set Layout to 1 Field
c.) Set Field 1 to ConnectIQ Fields, DozenRun
d.) run happy!
INSTALL ISSUES:
-"!" Issue: If you receive a "!", completely uninstall, reboot and then reinstall. The Setting file changed and the automated Garmin install is not replacing the setting file.
-Download Issue: if you have the "App requires an update before install", hard reboot your watch TWICE and install again.
-TIMER Issue: If you update/install and you see the TIMER and don't see the Dozen data field.
--The data field update or install may require a restart of watch.
--Or the data field needs added to the built-in application, again.
These are becoming a Data Field Suite, where all field are similar making it easier to read while in an activity.
The Dozen fields are intended for training, the data field works fine for speed work, track or races, but readability in these conditions maybe tougher.
IMPORTANT: If you have a Question, recommendation or problem.
Please provide as much as possible (for example the following):
1.) Watch type, Watch firmware version and ConnectIQ version.
2. programmed from Garmin Connect (phone type) or Garmin Express
3.) Which data field
4.) description of issue
5.) if its a "!" error include the error log from your watch. Connect your watch to a PC using USB cable. The error log is located x:\GARMIN\APPS\LOGS. copy the listing and paste in the post.
Layout Dozen Run Datafield fenix3
Cad|HR
Pace|Distance
Battery meter
Avg Pace| (bluetooth) Timer
Calories|Time|Elevation
GPS
Layout Dozen Run Datafield FR 230/235/630
Cad|HR
Pace|Distance
Battery meter
Elevation|Time|Calories
GPS
Layout Dozen Run Datafield FR 920XT
Pace|Timer
Battery meter
Avg Pace|HR| (bluetooth) Distance
Cad |Time|Elevation
GPS
Layout Dozen Cycle Datafield
Cad|HR
Speed|Distance
Battery meter
GPS
Layout Dozen Swim data field
Laps | SWOLF
Pace| Distance
Battery meter
Average Pace | (bluetooth) Timer
Calories| TIME | Stroke Type
GPS
Layout Dozen Paddle Datafield
AHR|HR
Speed|Avg SPD
Battery meter
Timer| Distance(bluetooth)
Cad|Time|AVG CAD (stroke distance)
GPS
Description for all fields
--All watch types are support for all data fields. Coded simple to keep bugs at minimum.
-Race Prediction completely configurable for any distance. Distance is entered in meters. Enter 1%-2% longer distance to adjust for normal GPS error and better race prediction.
-Cadence either from watch, footpod or crank cadence. Color coded to provide instant readability
-Heart Rate field is configurable to several methods: calculation (default), manual entered max HR, or individual zones Color coded to provide instant readability
-Pace/Speed is a rolling average to give a smooth reading configurable from 1 second to 120 seconds (Metric or statute by user setting)
-Distance is the total distance for the activity (Metric or statute by user setting)
-Timer is the actual time of the active time. Not Elapsed time.
- Battery meter uses the entire screen for reliability and acts as a divide to help focus one the upper fields.
-Avg Pace\Speed is a Garmin's provided datafield. (Metric or statute by user setting)
-Calories is the activity calories.
-Elevation based on Garmin's values. (Metric or statute by user setting)
-Time of day either in 12hr or 24 hour (based on user setting)
-(Fenix3/920)Auto background color Black or White background based on app settings
-(230/235) Configurable background color Black or White background (user configuration)
-GPS uses same indicator as iPhone for GPS signal. 5=full, 4=usable, 3=poor, 2=unused, 1= last location & 0 = no GPS
-Blue Tooth connectivity is shown as a blue "B"
-Paddle Stroke distance is a calculated by actual speed / cadence. Displayed in Meters/Feet.
#runhappy
  • Time of day missing in DozenRun
    Hi,
    yesterday I updated DozenRun on my Fenix3 to version 4.3. During my workout I saw, that in the lower center field above the GPS signal there is no longer the time of day. Instead there is a duplication of distance. Is this intentional?
    Many thanks for the data field by the way!
    Markus
  • My error log from Dozen Run
    Watch: 735XT
    Software: 7.20.0.0
    WARNING: Failed in data field compute
    STORE_ID: 9ff75afad594431189f7f92ca02118ad
    WARNING: Failed in onTimerLap/onTimerStart/onTimerStop event
    ERROR: Invalid Value
    DETAILS: Failed invoking <symbol>
    CALLSTACK:
    @PC = 0x00000000
    ERROR: Symbol Not Found Error
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    I have allready tried
    1. remove it.
    2. Hard reboot x 2
    3.Install Again
    4. Hard reboot.
  • Log file from crash
    Check the app store There is a new version 4.2.2 that address this. If you still have an issue contact me directly.
    I have the same problem with my 735XT and its running 4.3
  • log fil
    Here is my log:
    CALLSTACK:
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    CALLSTACK:
    @PC = 0x00000000
    Dozen Swim
    Hi!
    I am using the Dozen Swim-Datafield on the fenix 5x. I have set up different Apps for pool swimming according to the pool length (17m, 25m, 50m).
    Is it possible to read out the configured pool length out of the App instead of changing the configuration inside the data filed every time?
    Thanks
    Sven
  • I have the same problem with my 735XT and its running 4.3
    contact me directly through the app store contact developer link
    ReCAPTCHA rrallac pierre
    First of all, thanks for the GREAT data field! Thanks for supporting this community! I WISH I had the time to learn how to make these things like you can.
    Second, a couple of questions:
    -The GPS dots, how can you tell which ones are the "filled" ones or not? May be a dumb question, but how do you know if you have good GPS signal vs not? Does a dark dot mean good or does a white dot mean good?
    -Is there anyway to show how far behind or ahead of a predicted time you are doing? Say you program in for a 5K, and you want to run at a 10min pace. Can it show you if you are ahead or behind and by how much? I know there are other data fields that do this, but it would be nice if this one could do it as well.
    -What is the value that is displayed above the GPS dots in the same box as the GPS dots?
    Thanks!
  • First of all, thanks for the GREAT data field! Thanks for supporting this community! I WISH I had the time to learn how to make these things like you can.
    Thanks!
    I have a Vivoactive HR, but on my watch the black/filled in dots represent GPS signal. The more black dots, the better the signal.
    The number above the GPS dots is the time of day.
  • -Is there anyway to show how far behind or ahead of a predicted time you are doing? Say you program in for a 5K, and you want to run at a 10min pace. Can it show you if you are ahead or behind and by how much? I know there are other data fields that do this, but it would be nice if this one could do it as well.
    Yes, but only in the newer IQ 2.x watches.
    Thanks for this really great app.
    I am using it on a forerunner 235.
    Is there an option to display speed rather than pace?
    My only other request would be the ability to record TRIMPexp as per
    http://fellrnr.com/wiki/TRIMP#TRIMPexp_Exponential_Heart_Rate_Scaling
    Cheers!
