Data Field: Dozen Run Fields
Dozen Run, Swim, Paddle and Cycle Data Fields
After others are forcing you to pay for these applications, so I decided to make a great data field(s) and then keep them free. I'm a Software engineer, sponsored runner and run coach, I combined my engineering and running knowledge to bring you these streamline applications.
I put thousands of hours of bench and field testing these simple applications. So, consider a small donation.
Small donations (help keep my effort going) paypal.me/fbbbrown
Install Instructions:
This Data field needs to be added to the (specific) app within your watch to view.
This is a data field not an application and needs to be added to a single data screen within an application.
a.) Goto settings,apps,run,data screen,screen 1
b.)Set Layout to 1 Field
c.) Set Field 1 to ConnectIQ Fields, DozenRun
d.) run happy!
INSTALL ISSUES:
-"!" Issue: If you receive a "!", completely uninstall, reboot and then reinstall. The Setting file changed and the automated Garmin install is not replacing the setting file.
-Download Issue: if you have the "App requires an update before install", hard reboot your watch TWICE and install again.
-TIMER Issue: If you update/install and you see the TIMER and don't see the Dozen data field.
--The data field update or install may require a restart of watch.
--Or the data field needs added to the built-in application, again.
These are becoming a Data Field Suite, where all field are similar making it easier to read while in an activity.
The Dozen fields are intended for training, the data field works fine for speed work, track or races, but readability in these conditions maybe tougher.
IMPORTANT: If you have a Question, recommendation or problem.
Please provide as much as possible (for example the following):
1.) Watch type, Watch firmware version and ConnectIQ version.
2. programmed from Garmin Connect (phone type) or Garmin Express
3.) Which data field
4.) description of issue
5.) if its a "!" error include the error log from your watch. Connect your watch to a PC using USB cable. The error log is located x:\GARMIN\APPS\LOGS. copy the listing and paste in the post.
Layout Dozen Run Datafield fenix3
Cad|HR
Pace|Distance
Battery meter
Avg Pace| (bluetooth) Timer
Calories|Time|Elevation
GPS
Layout Dozen Run Datafield FR 230/235/630
Cad|HR
Pace|Distance
Battery meter
Elevation|Time|Calories
GPS
Layout Dozen Run Datafield FR 920XT
Pace|Timer
Battery meter
Avg Pace|HR| (bluetooth) Distance
Cad |Time|Elevation
GPS
Layout Dozen Cycle Datafield
Cad|HR
Speed|Distance
Battery meter
GPS
Layout Dozen Swim data field
Laps | SWOLF
Pace| Distance
Battery meter
Average Pace | (bluetooth) Timer
Calories| TIME | Stroke Type
GPS
Layout Dozen Paddle Datafield
AHR|HR
Speed|Avg SPD
Battery meter
Timer| Distance(bluetooth)
Cad|Time|AVG CAD (stroke distance)
GPS
Description for all fields
--All watch types are support for all data fields. Coded simple to keep bugs at minimum.
-Race Prediction completely configurable for any distance. Distance is entered in meters. Enter 1%-2% longer distance to adjust for normal GPS error and better race prediction.
-Cadence either from watch, footpod or crank cadence. Color coded to provide instant readability
-Heart Rate field is configurable to several methods: calculation (default), manual entered max HR, or individual zones Color coded to provide instant readability
-Pace/Speed is a rolling average to give a smooth reading configurable from 1 second to 120 seconds (Metric or statute by user setting)
-Distance is the total distance for the activity (Metric or statute by user setting)
-Timer is the actual time of the active time. Not Elapsed time.
- Battery meter uses the entire screen for reliability and acts as a divide to help focus one the upper fields.
-Avg Pace\Speed is a Garmin's provided datafield. (Metric or statute by user setting)
-Calories is the activity calories.
-Elevation based on Garmin's values. (Metric or statute by user setting)
-Time of day either in 12hr or 24 hour (based on user setting)
-(Fenix3/920)Auto background color Black or White background based on app settings
-(230/235) Configurable background color Black or White background (user configuration)
-GPS uses same indicator as iPhone for GPS signal. 5=full, 4=usable, 3=poor, 2=unused, 1= last location & 0 = no GPS
-Blue Tooth connectivity is shown as a blue "B"
-Paddle Stroke distance is a calculated by actual speed / cadence. Displayed in Meters/Feet.
#runhappy
    Settings
    I'm really sorry, I'm sure this is covered somewhere; I just can't seem to find it.
    I can get to the data field settings via my android phone, but I'm unable to read the description for each settings (they are cut off) and therefore not sure what values to input. In the reviews I saw someone say that you need to use your PC to access these settings...I cannot for the life of me figure out how to do that.
    Any advice would be very appreciated.
    Thanks!
    -Jerry
    I'm using a 235
    Connect version number 3.6.0.1
    Hi these are great data fields. Would it possible in the cycling one to change the altitude field from the current altitude to meters climbed? I would find that of more interest.
    Oh ... I would like to have this for the run version ... this is some really nice data field, but I think total ascent would be more appropriate here as well. currently this is on its own three field screen (total ascent, elevation, total descent) but right now I really stay on the dozen run field almost all the time. THANKS!
  • I'm really sorry, I'm sure this is covered somewhere; I just can't seem to find it.
    Thanks!
    -Jerry
    I'm using a 235
    https://forums.garmin.com/showthread.php?332843-How-to-App-Settings
  • Oh ... I would like to have this for the run version ... this is some really nice data field, but I think total ascent would be more appropriate here as well. currently this is on its own three field screen (total ascent, elevation, total descent) but right now I really stay on the dozen run field almost all the time. THANKS!
    What watch flavor?
    total ascent, i will look into this.
  • Pace was blank (0.00) I n my just completed pool swim.
    I believe that is the actual pace so if you stopped it will goto zero. This data field i will be revisiting to refine.
  • I have the most uptodate version of the dozen cycle, but my watch shows it as 1.3.5, but the connect store shows it as 1.3.7.1? Any ideas?
    Fenix 3
  • I believe that is the actual pace so if you stopped it will goto zero. This data field i will be revisiting to refine.
    Thank you! To be more precise: pace read as 0.00 throughout the entirety of my swim.
    best!
    Fenix 3
    You could try reboot the watch, this worked for me.
    Fenix 3
    i've personally seen this it's a garmin thing. try restarting the watch.
  • Thank you! To be more precise: pace read as 0.00 throughout the entirety of my swim.
    best!
    Verified on another swim, while moving. Short pool, 10sec rolling average time.
