Data Field: Dozen Run Fields
Dozen Run, Swim, Paddle and Cycle Data Fields
After others are forcing you to pay for these applications, so I decided to make a great data field(s) and then keep them free. I'm a Software engineer, sponsored runner and run coach, I combined my engineering and running knowledge to bring you these streamline applications.
I put thousands of hours of bench and field testing these simple applications. So, consider a small donation.
Small donations (help keep my effort going) paypal.me/fbbbrown
Install Instructions:
This Data field needs to be added to the (specific) app within your watch to view.
This is a data field not an application and needs to be added to a single data screen within an application.
a.) Goto settings,apps,run,data screen,screen 1
b.)Set Layout to 1 Field
c.) Set Field 1 to ConnectIQ Fields, DozenRun
d.) run happy!
INSTALL ISSUES:
-"!" Issue: If you receive a "!", completely uninstall, reboot and then reinstall. The Setting file changed and the automated Garmin install is not replacing the setting file.
-Download Issue: if you have the "App requires an update before install", hard reboot your watch TWICE and install again.
-TIMER Issue: If you update/install and you see the TIMER and don't see the Dozen data field.
--The data field update or install may require a restart of watch.
--Or the data field needs added to the built-in application, again.
These are becoming a Data Field Suite, where all field are similar making it easier to read while in an activity.
The Dozen fields are intended for training, the data field works fine for speed work, track or races, but readability in these conditions maybe tougher.
IMPORTANT: If you have a Question, recommendation or problem.
Please provide as much as possible (for example the following):
1.) Watch type, Watch firmware version and ConnectIQ version.
2. programmed from Garmin Connect (phone type) or Garmin Express
3.) Which data field
4.) description of issue
5.) if its a "!" error include the error log from your watch. Connect your watch to a PC using USB cable. The error log is located x:\GARMIN\APPS\LOGS. copy the listing and paste in the post.
Layout Dozen Run Datafield fenix3
Cad|HR
Pace|Distance
Battery meter
Avg Pace| (bluetooth) Timer
Calories|Time|Elevation
GPS
Layout Dozen Run Datafield FR 230/235/630
Cad|HR
Pace|Distance
Battery meter
Elevation|Time|Calories
GPS
Layout Dozen Run Datafield FR 920XT
Pace|Timer
Battery meter
Avg Pace|HR| (bluetooth) Distance
Cad |Time|Elevation
GPS
Layout Dozen Cycle Datafield
Cad|HR
Speed|Distance
Battery meter
GPS
Layout Dozen Swim data field
Laps | SWOLF
Pace| Distance
Battery meter
Average Pace | (bluetooth) Timer
Calories| TIME | Stroke Type
GPS
Layout Dozen Paddle Datafield
AHR|HR
Speed|Avg SPD
Battery meter
Timer| Distance(bluetooth)
Cad|Time|AVG CAD (stroke distance)
GPS
Description for all fields
--All watch types are support for all data fields. Coded simple to keep bugs at minimum.
-Race Prediction completely configurable for any distance. Distance is entered in meters. Enter 1%-2% longer distance to adjust for normal GPS error and better race prediction.
-Cadence either from watch, footpod or crank cadence. Color coded to provide instant readability
-Heart Rate field is configurable to several methods: calculation (default), manual entered max HR, or individual zones Color coded to provide instant readability
-Pace/Speed is a rolling average to give a smooth reading configurable from 1 second to 120 seconds (Metric or statute by user setting)
-Distance is the total distance for the activity (Metric or statute by user setting)
-Timer is the actual time of the active time. Not Elapsed time.
- Battery meter uses the entire screen for reliability and acts as a divide to help focus one the upper fields.
-Avg Pace\Speed is a Garmin's provided datafield. (Metric or statute by user setting)
-Calories is the activity calories.
-Elevation based on Garmin's values. (Metric or statute by user setting)
-Time of day either in 12hr or 24 hour (based on user setting)
-(Fenix3/920)Auto background color Black or White background based on app settings
-(230/235) Configurable background color Black or White background (user configuration)
-GPS uses same indicator as iPhone for GPS signal. 5=full, 4=usable, 3=poor, 2=unused, 1= last location & 0 = no GPS
-Blue Tooth connectivity is shown as a blue "B"
-Paddle Stroke distance is a calculated by actual speed / cadence. Displayed in Meters/Feet.
#runhappy
    Hi, about time someone consolidated the important fields. Just one suggestion, many guys don't have cadence meters, or if your on a mountain bike on a trail, it's impossible to maintain cadence.
    Would be nice as a Dozen MTB datascreen, to have average heart rate instead of cadence.
    Thx
    Koos
    It's called Dozen RUN fields - not dozen cycle field. That cadence field is for running cadence which many of these watches support so is definitely a good field to have.
  • Hi, about time someone consolidated the important fields. Just one suggestion, many guys don't have cadence meters, or if your on a mountain bike on a trail, it's impossible to maintain cadence.
    Thx
    Koos
    Thanks, Cool Idea! :cool:
    That's not hard to add and I'll keep that in mind when I update again. This would be an auto detect field, since the value may be a NULL (no value) and I would switch in a different value and text label.
    EDIT!! Done! check app store for bike data field for the 23x/63x and it does what you asked. Fenix users I will be updating soon after I try it out. (need a non-snowy day)
    going back to defaults helped.
    The android connect is known for issues. For the android install, try to uninstall, reinstalled and use the defaults.
    Better option is to use Garmin express.
    If you can post the contents of garmin\apps\log. So I can address the android issue. Note I don't have an android phone so I cannot test it.
    Hi,
    resetting to the defaults made it work again.
    This is the log i have:
    ERROR: Unhandled Exception
    DETAILS: Failed invoking <symbol>
    STORE_ID: 9ff75afad594431189f7f92ca02118ad
  • Hi these are great data fields. Would it possible in the cycling one to change the altitude field from the current altitude to meters climbed? I would find that of more interest.
  • Hi,
    Appears to be a null value coming from the connect custom values. I've made changes to prevent the crash"!" But I can't prevent the bad values coming from connect. I will update on Monday.
  • Dozen Cycle for fenix3
    I found a bug within the SDK that allowed a bad format, that caused the dreaded "!".
    update to 1.3.4. that will correct the issues.
    1.3.4
    addes
    avg heartrate to upper left field if no cadence is detected
    lower left field is configurable. Calories or total ascent
  • Thanks for adding total ascent! Really appreciated.
    White bg and some ideas
    As of two versions ago the background is configurable. Try updating the data field if there is still an issue, reply here. thanks
    By some reason, the option was not there.
    But I deleted GQE (eventhough it was the newest version).
    And reinstalled it. Now it works and I "found" the white background.
    This data screen is the best!
    If you however are looking for improvement ideas for the run field:
    Add option of rolling/rotating fields (user edits in GQE)
    In such a way that
    Avg speed or Lap speed orLap + Avg speed with 8 sec rotation Avg speed in black, lap speed in red.
    Same goes for distance
    Where you would have a similar fileld as the hFinish mini [
  • 920XT Borometer / GPS / CAD display
    First, thanks for this great datafield !
    I am using 920XT version and I think I have a little problem for the display of barometer / gps / Cal : all the 3 datas are shown in the same time !
    I try to change in the parameter via Connect IQ, but it displays always the 3 datas.
    I've got Firmware 6..20.
  • First, thanks for this great datafield !
    Thanks, check back for an update. I fixed the bug.
    Also, corrected the background color selection. I thought this was a changeable item in the 920xt. Now this is configurable in Connect or Garmin Express.
