BRIANBAN datafields, watchfaces and apps
Please use this thread to ask for support, changes, give app ideas and if you like the apps let me know.
Published right now:
Apps shown here: https://apps.garmin.com/en-US/developer/7d3f463d-7b44-48c0-9b74-b7e5ce25f7bb/apps
I'm working on the Pacer data field and a new version of Hi-Vis runfield.
Source code repositories are:
Pacer: https://gitlab.com/nz_brian/garmin.pacer
Hi Vis Run Field: https://gitlab.com/nz_brian/HiVisRunField
Large time and distance in one line: https://gitlab.com/nz_brian/garmin.datafield.timeanddistance
Doubletime: https://gitlab.com/nz_brian/garmin.datafield.doubletime
AnalogPlus: https://gitlab.com/nz_brian/garmin.watch.analogplus
  • Thanks, I was just thinking that 2 large fields in the middle row is what I need.
    Would also like a lap time/lap distance version of "Datafield: Large time and distance in one line (kms)"
    Is it possible to make a smaller colon character btw, not to touch the surrounding numbers?
  • There is a value in System::DeviceSettings called "distanceUnits" that you could use to display miles or kms using the same DF based on the device settings.
    Just a suggestion, but could reduce the versions you need to maintain. And maybe "is24Hour" for 12/24 hr display of time if you show TOD anyplace.
  • i like how yo made the 2 fields look like 1 large field.
    I presume in the code - there's nothing magic, just careful placements of the characters?
    Former Member over 9 years ago
    I would suggest to have a Pace/Heart Rate in one line, in addition, will the text change to white with dark background if I choose it in vivo?
    Yes, very creative. I don't need it, but a big thumbs up. I assume it's just showing the upper and lower part of the same data field, with a huge font. Cool!
    Awesome thanks! I'll have a look.
    <Update>
    I had a look and that works perfectly thanks. I've updated the app to use this at:
    https://apps.garmin.com/en-US/apps/85548dc0-b68e-4797-9738-25a132c9f2d4
  • I would suggest to have a Pace/Heart Rate in one line, in addition, will the text change to white with dark background if I choose it in vivo?
    Hey. No sorry the text and background colours are fixed. There may be a way to pick up the selection you make in settings. I'll try and have a look next time I'm coding.
  • Yes, very creative. I don't need it, but a big thumbs up. I assume it's just showing the upper and lower part of the same data field, with a huge font. Cool!
    Yes exactly! The fields all update at almost exactly the same time so it works.
    It's a shame you can't use 3 custom datafields, or you could do some very cool things with the screen pretty simply.
  • Vivoactive displays not readable while running.
    I cannot read the display on my Vivoactive while running, so the app with the larger font would help me. But, for some reason I get an error message every time I try to download it.
    Please can you create a black background version.
