Problems with vscode extension and sdkmanager on linux
Hello,
I just downloaded the sdkmanager and the vscode extension.
Vscode couldn't find the extension, so i downloaded it from the website and installed it manually. Then, i restarded vscode, but when in press cntrl+shift+p and type "verify extension", i cant find anything from monkeyc.
Sdkmanager started and installed without any bigger problems, but also here, its not possible, to type any command like monkeydo, because the command can't be found.
Did somebody experienced anything similar on linux and can help me fixing this?
  • connect iq indeed only support ubuntu lts releases (and even when using those it seems like an issue where sometimes old libraries are referenced). You can use arch linux if you want, but you're basically on your own when you're using that one.
    Yes, but why are you still using Linux?
    one reason can be that you don't need to purchase a license to use the os.
