I often run using map and found it very anoying. I would like to implement few ideas but leave the rest of the app as is.
Is there a way to extend the existing app using API (not build it from scratch)?
If it's a CIQ app you're talking about, it can only be extended by the developer or if the developer gives you access to the source code where you can make the changes.
