When I'm working with two projects (current release and a test version), I cant switch between projects for build and simulator.
Every time only the first used project is used for the build since VS code was started. Open a new mc file and start build or simulator doesn't work. VS Code is starting the other project again, not the currently opened file.
If VS Code is closed and restarted, I can use the other project. But only this one. For every switch between projects I have to close and restart VS Code.
Ist this a bug or are settings missing in my environment?
