Error: Illegal Access (Out of Bounds) when creating new class-instance
I spent hours debugging, but can't find out the reason for this Error:
Details: Failed invoking <symbol>
Stack:
  - getServiceDelegate() at /source/NSFaceApp.mc:34 0x10000079
Can someone help figure this out?
The source files:
// NSFaceApp.mc
using Toybox.Application as App;
using Toybox.WatchUi;
using Toybox.System as Sys;
using Toybox.Background;
using Utils;
var controller;
(:background)
class NSFaceApp extends App.AppBase {
    function initialize() {
        AppBase.initialize();
    // onStart() is called on application start up
    function onStart(state) {
    // onStop() is called when your application is exiting
    function onStop(state) {
        controller.unregisterBackgroundEvent();
    // Return the initial view of your application here
    function getInitialView() {
        controller.registerBackgroundEvent();
        return [ new NSFaceView() ];
    // This function is called when the temporal event occurrs
    function getServiceDelegate(){
        var c = new Utils.Controller();
        c.initState();
        Utils.validateAndUpdateURL();
        controller.setBackground(true);
        return [new NSFaceBackground()];
    // This function passes data back to the main process when
    // BG process has exited
    function onBackgroundData(data) {
        controller.onBackgroundData(data);
    // New app settings have been received so trigger a UI update
    function onSettingsChanged() {
        WatchUi.requestUpdate();
// Utils.mc
module Utils{
    function validateAndUpdateURL() {
    class Controller {
        function initState() {
        function getState() {
        function setState(data) {
        function getUrl() {
        function getUnit() {
        function registerBackgroundEvent() {
        function unregisterBackgroundEvent() {
        function setBackground(_inBackground) {
        function makeNightscoutRequest() {
        function processResponse(responseCode, data) {
