This one really doesn't do much.  It displays the time, an indication if it's on a device that supports background processes (you can see how that's checked in the App Class), The count of the times the background process has run, and the data returned from the background.  It does cache data in the object store, so after the first time the background runs, it will have data.
The background process is a Temporal event, and runs every 5 minutes.  All the background does is return a string with a time stamp (HH:MM).  There are a number of Sys.println() calls to see what's going on.  If you have a watch that supports background processes (f5's,chronos,935,735,va-hr), create a <myapp>.txt in logs to catch the println() calls, as you see kind of a neat thing where those that come from the background are marked as such!
This runs in the sim can you can use the code to build a sideload.  In addition to devices that support background processes, I included the fenix 3 as a target so you can see how it works on a watch that doesn't.
if you have questions about the code, just ask!
