Hi,
I'm having trouble with using an animation on my Watch Face. Specifically, I've drawn a bunch of text and bitmaps through onUpdate, but at the start of a specific hour I would like the watch to only play a gif completely before showing everything else again. Based on the sample app example, as well as another I found, I had no issues with encoding and playing a gif on a real watch using the motion tool. However, the problem arises when I try to "transition" to an animation from a state where there are only bitmaps/text on the screen. As a simplified example, based on the sample app code I linked, this is what I'm doing:
// global vars
private var _aniDone = false;
var _aniInProg = false;
function onUpdate(dc) {
View.onUpdate(dc);
hour = System.getClockTime().hour;
//System.println(System.getClockTime().sec);
// when the animation is done, kill it
if (_aniDone == true && _aniInProg == true) // _aniInProg so we only run once
_aniDone = false;
System.println("Done");
_animationDelegate.handleOnHide(self);
WatchUi.requestUpdate();
// play an animation at a particular time
if (hour == 0)
if (_aniInProg != true) // run once
System.println("Animation starting");
_animationDelegate.handleOnShow(self);
_animationDelegate.play();
_aniInProg = true;
// stuff drawn on screen
dc.setColor(Graphics.COLOR_BLUE, Graphics.COLOR_TRANSPARENT);
dc.drawText(100, 100, Graphics.FONT_NUMBER_MEDIUM, hour, Graphics.TEXT_JUSTIFY_CENTER);
dc.clear();
with_aniDone set to true in the WatchUi.ANIMATION_EVENT_COMPLETE event. The code works fine on the simulator (I set the time to 11:59:55 pm and just wait out a few seconds), but on a real watch, the watch face will not play the animation unless I leave and then reenter the view. I am unable to transition "directly" to the animation playback, even with the Ui.requestUpdate() call. I've tried changing the logic a bit (e.g., checking the hour and then putting everything inside that condition) but the results are the same.
How can I fix this? Is my approach correct? This seems like it should be a fairly simple thing to resolve, and I haven't found any previous threads on it.
I'm including the AnimationController and AnimationDelegate codes below for completeness.
using Toybox.WatchUi;
class DanceDanceAnimationController {
private var _animation;
private var _playing;
function initialize() {
_playing = false;
function handleOnShow(view) {
if( view.getLayers() == null ) {
// Initialize the Animation
System.println("controller: initializing animation");
_animation = new WatchUi.AnimationLayer(
Rez.Drawables.dark_hour,
:locX=>0,
:locY=>0,
view.addLayer(_animation);
function handleOnHide(view) {
System.println("controller: Clearing animation");
view.clearLayers();
_animation = null;
function play() {
if(!_playing) {
System.println("controller: animation playing");
_animation.play({
:delegate => new DanceDanceAnimationDelegate(self)
_playing = true;
function stop() {
if(_playing) {
System.println("controller: animation stopping");
_animation.stop();
_playing = false;
// This class bridges communication between the app and the animation
// playback
class DanceDanceAnimationDelegate extends WatchUi.AnimationDelegate {
var _controller;
// Constructor
function initialize(controller) {
AnimationDelegate.initialize();
_controller = controller;
// Animation event handler
function onAnimationEvent(event, options) {
switch(event) {
case WatchUi.ANIMATION_EVENT_COMPLETE:
_aniDone = true;
case WatchUi.ANIMATION_EVENT_CANCELED:
_controller.stop();
break;
