I am using ANT Time sync to get very accurate timing data from a lap trigger. The accuracy is better than 1ms.
using the ANT.Message.timestamp, I can get the time stamp of the received ANT message generated off a 32.768kHz clock, but this is read some short time after the ANT event. I know that I can use System.getTimer to get current milliseconds but can't see how to get the time offset between the two.
Is there a way to get the 32.768kHz clock time outside of using Message.timestamp?
