Can someone help me with setting up connect iq sdk + eclipse? Eclipse is not necessary, terminal scripts are fine as well as I don't need a lot of them and the eclipse plugin is very basic anyways.
It looks like the process is like following:
- check https://developer.garmin.com/connect-iq/sdk/ and find out there is no SDK for linux... at least not if I open this page from within linux
- find out that there exists a json file here https://developer.garmin.com/downloads/connect-iq/sdks/sdks.json
- get the sdk name from this json and use it in this link: https://developer.garmin.com/downloads/connect-iq/sdks/<DESIRED-SDK-NAME>.zip
- finally download the sdk
- extract it and find out there is no SDK Manager in it? only era, fit-graph and monkeybrain (last one does not start at all)
Additionally I did the eclipse SDK setup like described here: https://developer.garmin.com/connect-iq/sdk/
The first problem that comes up is that I can't start a SDK manager as I can't find one... Can someone help here?
PS:
I also found this link that contains the sdk manager https://developer.garmin.com/downloads/connect-iq/sdk-manager/connectiq-sdk-manager-linux.zip but this one does not start at all...
