Time Simulation not available in Simulator
Hello,
I installed the SDK and the Eclipse Plugin on two PCs.
PC 1: In the Simulator, the menu item Simulation > Time Simulation is grayed out
PC 2: The menu item Time Simulation is available and works as expected
Has anyone an idea, why the menu item is not available on both PCs? Is there a dependency I missed when installing on PC1? Is there something I might installed wrong on PC 1?
I also discovered another difference:
My watchface project compiles without error on both PCs and runs in the simulator on both PCs. Although time updates on PC 2 while time is frozen to the start time on PC 1.
PC 1: If copied to my watch with the Eclipse menu item "Connect IQ > Build For Device Wizard" result in an app that is completely ignored by the watch
PC 2: Using "Build For Device Wizard" result in an app that is executed by the watch
The only obvious difference is, that PC 1 uses Eclipse Version Oxygen and the PC2 uses Ecplips Version Mars.
I use the same developer key for both PCs.
I hope someone has an idea what might cause the trouble on PC 1
Andreas
