Hello,
I have been trying a couple of things but still I cannot solve this problem.
I am developing quite a simple Application, which shall include sending data via HTTP requests.
There is one request to receive data and one to send. I can see that there is a connection but it sends empty files.
What do I need to do to send the heart rate with the HTTP-Post?
The code I use is the following
function onSend(responseCode, stream) {
Sys.println("OnSend " + stream);
stream = model.getHeartRate();
//check if request was successful
if (responseCode == 200) {
Sys.println("Sending Successful");
} else {
Sys.println("Response Send: " + responseCode);
Ui.requestUpdate();
function sendData() {
var url = www.placeholder.com //I am testing with a local IP
var params = stream;
// define the HTTP methods and response type
var options = {
:method => Communications.HTTP_REQUEST_METHOD_POST, // set HTTP method
:headers => {"Content-Type" => Communications.REQUEST_CONTENT_TYPE_JSON},
:responseType => Communications.HTTP_RESPONSE_CONTENT_TYPE_JSON // set response type
// set responseCallback
var responseCallback = method(:onSend);
// make the Communications.makeWebRequest() call to send data
Communications.makeWebRequest(url, params, options, method(:onSend));
Thank you in advance for your help.
