I got 3 reports that my app does not work on garmin 1030 on the simulator and others garmin is working fine can some one verify i don't´ have this garmin thanks
apps.garmin.com/.../cc82bb53-c7b3-4a53-8a87-b5cfbf0378c5
Hi,
You should try to run ERA, this may give you information on the crashes.
thanks, but how do i get my developer number, i got the file but not the number
thanks a lot yes there's an error
Error Name: Unexpected Type Error
Occurrences: 12
First Occurrence: 2020-02-14
Last Occurrence: 2020-02-14
Devices:
Edge® 1030: 9.10
App Versions: 3.1.3
Languages: ita
Backtrace:
PowerEdgeField3View.onUpdate:301
i fixed an error on a line 301 and it does not appear the error again, did it get fixed??
U will know next time.
next time is downloaded by someone??
The errors occur when the apps are run. So, somebody would have to download and run it.
If you fixed a bug on 301, it's not likely you'll see a report for it (unless you didn't really fix it).
I have an Edge530 the Aeropod app was working, could this be a similar error with edge1030 ?
my error is this, it's underlined, it's not crashing the app but the avgTime does not work, should i use:
power = functionP: instead of var power = functionP;
or should i use avTime = avgTime;
if (mTimerRunning){
if (info.elapsedTime != null){
if (currentTime == null) {
currentTime = (info.elapsedTime/3600);
avgTime = ((info.elapsedTime/3600) - currentTime);
if (power > 0){
avTime = avTime + (avgTime - avTime);
avPower = avPower + ((power - avPower) / avTime).toNumber();
pPower.setData(avPower.toNumber());
