Watch Face will not change
Hi,
I’ve tried changing the watch face on my Fenix 3 but it will not change at all. Ive even tried removing all the watch faces from the watch on Garmin Express. Once I confirm there are no watch faces on the watch memory I try to change it to the digital face. Still won’t change!!!
Any ideas.
  • I'm guessing that you're doing something wrong or you are using very old firmware. What firmware version are you using? Can you provide step-by-step instructions on the process that you follow to install the watch face and then select it on the device?
    Former Member over 9 years ago
    Hi,
    I sometimes have the same behaviour on my VivoActive. Did you try to sync the new watchfaces and the restart the device?
    Greets
