Is it possible to create a widget that alerts you when a certain temperature (definable by the user) is reached (with a connected Garmin tempe sensor)?
This would require a background service that runs every 5 minutes, The way that a background works is it can run at most for 30 seconds at a time.
And with a tempe, it can take a minute to connect, so the background wouldn't connect many times it's attempted.
Plus connecting to the tempe would be a significant battery drain in this case.
Thanks for your detailed answer
