Trying to map a route over roads I’ve ridden loads and mapped on my garmin 830 before but keep getting this error message. Is there an issue with garmin in the U.K. today?
‘We have limited popularity data for this part of the map’
Not sure if anyone ever called when the issue first started. The US is now on holiday until Saturday. If the issue persists at that time, I'll try to engage support again.
As promised…
The same thing happened last month. I contacted Garmin Support using the chat option. It was fixed by the next day. Create Roundtrip: Oops, something went wrong. Dismiss
Not sure if anyone ever called when…
Yup, getting the same error.
Hi, I haven't been able to create train paths in the Garmin Connect app for 4-5 days. There is a notice that says "Limited Available Data" "Sorry, popularity data for this area of the map is limited. You may not be able to use this feature in this area." This used to not happen and I could create my train paths without problems. What can it be because of? Thank you.
This is a known issue and it is not specific to the iOS or android apps. Merging your thread with the parent thread.
I am no longer able to plan road cycling routes on the iPhone app as whenever I try to plot a custom route it tells me “limited data available. Sorry, we have limited popularity data for this area of the map. You may not be able to use this feature in this area” and won’t let me add the next point.
It looks like a problem that would be solved by selecting “follow roads” or “freehand” rather than “popularity route” but there is no longer any option to change this in the app.
I know that this can still be done on the garmin connect website and route planning is easy there but planning routes from my phone is often more convenient. I’ve tried reinstalling the app but nothing changed.
any ideas how to avoid using popularity routes as the default on the app?
This morning I noted that it's impossible to create a new course, while it was last Sunday for sure.
Does anybody have same issue? Even using "custom mode" most of the time the next point addition fails complaining there are no possible route, even if there's a plain road in between. Trying more and more, after a while GC is able to find the path, but the problem repeats for every additional point, so quite boring creating a complete path.
Is it a bug in Connect app?
Same problem in Cheshire . Worked fine last weekend (21 Nov 20 ) with same settings and location but haven’t had any joy since Friday of last week (27 Nov 20 ) which fits in with timescales mentioned when others had the problem. Have asked Garmin to look in to as it seems to be a problem with their web site base on the comments below
