Sync / Connection Troubleshooting Guide
  • The following checklist attempts to cover all possible reasons of failing synchronization. If you encounter connectivity problems, please read it carefully and eliminate one point after the other, not skipping any, even if you think it cannot help. All of the points are listed because they did help other users in the past cases. More tips will be added, if found useful.
Most common way people use for resolving this kind of problems, is uninstalling and reinstalling the application. Sometimes it can help, but often only temporarily, because you usually did not really resolve the true problem. So, although it is also a way how you can try fixing the issue, let us focusing also on other alternatives, and trying to find and eliminate the problem.
  1. A quick fix that works often when the connection gets stuck only occasionally, is toggling Bluetooth off and on, on the phone (swipe down the top status bar to access the BT icon), or (in a more persistent case) forcing the Garmin Connect Mobile app to stop and restarting it.
  2. First of all check out whether the latest version of software (firmware) is installed on your watch. If you can successfully connect to the watch with Garmin Express via the USB cable, try whether syncing works at least over the cable, and check also for the latest software update with it. Otherwise, look up the watch software version directly on the device (typically: long-press the Menu button » Settings » About, but it may depend on the watch model), and verify with the support page for your model on Garmin's website whether there is an update available.
  3. The next step to try would be a soft reset (typically - holding the Light button for some 20s, until the device shuts down), or powering down and powering up the device. It often fixes weird behavior, especially after firmware updates. Also shut down the GC Mobile app (iOS: swipe it up in the iOS App Switcher; Android: Android Settings » Apps » Connect » Force to Stop), and then restart it. No data, and no settings are being lost, during the soft reset (unlike at the master reset), so no need to worry about doing it.
  4. In the Privacy Settings of your Garmin Connect Web, make sure the options Storage & Processing and Device Upload are enabled
  5. In Device Settings in Garmin Connect Web, verify that the option Activity Tracking is enabled, and also verify whether the option Preferred Activity Tracker is checked in the Device Settings » Activity Tracking.
  6.  reported in this thread that the clearing the cache of the Garmin Connect app helped to fix the problem on his Google Pixel 2 phone. Accessible in Android Settings » Apps » Connect
  7. Check out the Sync Audit on the phone app, and search for any error messages of warnings. You can browse through the history of the audits on the screen GC Mobile Menu » Settings » Device Sync Audit (note the navigation buttons at the bottom of the screen to review also previous reports, and not only the last one)
  8. One of relatively frequent reasons for a stalled syncing is a corrupt FIT file, mostly a file of a recent Activity. Open the storage of your Garmin device over the USB cable in a file manager (such as File Explorer in Windows or File Finder in MacOS), and download the un-synced files from the folder //GARMIN/Activity (the date is used for the file names). Try importing those files by dropping them onto the Import page of Garmin Connect Web. In case some of the files triggers errors during the import, delete it from the device, and try repairing and reimporting the file using the Section Remover of  FIT File Tools (without removing anything), or consult the thread How to repair a .fit file?
  9. In some cases, especially with older devices, full storage may cause faulty FIT files and/or sync problems. Clean up regularly the folder /GARMIN/Activity, making sufficient room for new activities. You can also remove unneeded workouts (//GARMIN/Workouts/), courses (//GARMIN/Courses/), and language text files (//GARMIN/TEXT/)
  10. If the sync seems to be working OK (the circle around the watch symbol closes and the green do appears), but data like heart rate, steps, or activities does not appear on the phone,
    then your device might be misaligned with the GC account. Follow the instructions from the thread Troubleshooting guide for (some) data missing after syncing to resolve the issue.
  11. You sould also try turning off completely both your phone and the watch, waiting a moment, and then turning them back on again. Make sure Bluetooth is on, on both sides.
  12. When you go to the Bluetooth details on the phone (swipe down the top and long-tap the BT symbol), is your watch visible? If not, tap Scan up right. If yes, then in wich section? Available or Paired? If it is in the Available section, follow the installation instructions from you user manual and pair the devices.
  13. Try disconnecting all other BT active devices, such as headphones, etc.
  14. If the Garmin device is already paired with another phone (or a tablet, pc, …), remove the pairing.
  15. Check the menu on the BT screen (on the phone), check the Advanced options, and verify all parameters. On some phones there is an option for clearing the Bluetooth cache. If you find it, use it. If you don't, google it up for your phone model, or use the search function on the Android settings screen.
  16. Try removing the pairing of the watch from phone's BT devices, and re-pairing it from the phone's BT page (unlike what Garmin's User Manual suggests). If it does not help, remove the pairing again and try initializing the pairing from the watch, just like the User Manual tells. Sounds a bit foolish, but there are many users whom it helped.
  17. Verify all application permissions in Android Settings » Apps » Connect » Permissions. Check also other sections of the application page in the system settings. The manufacturer of the phone may have added additional parameters. Check all for any susceptible limitations. The Permissions are also accessible from Garmin Connect menu » Settings » Phone Permissions, they should be all turned on
  18. Try some troubleshooting guides from Garmin Support:
  19. Check the following troubleshooting guide for HUAWEI (should work for Honor and other clones too). It may apply to your phone perhaps too:
  20. Another tip for HUAWEI, although for notifications, may perhaps help for certain phones and syncing too:
  21. And yet more tips for HUAWEI owners: https://thedroidguy.com/fix-huawei-p30-bluetooth-connection-problems-bluetooth-not-working-1104602
  22. Another HUAWEI owner reports that disabled GPS location service caused troubles with the GC synchronization
  23. If you skipped the previous points, thinking it did not concern you, check out (on your phone) battery saving parameters, mobile data permissions or saving settings, and lock screen settings - all of them can hinder the communication in some cases (for example disabling the Bluetooth communication at low power, blocking web access when on mobile data, blocking the Garmin Connect background process when the screen is locked,...).
  24. On some phones (namely reported on several SAMSUNG models), you may need to reset the network settings, typically under Settings » General management » Reset » Reset network settings. Please note you'll loose all network settings for wi-fi and Bluetooth a will have to re-do them. (source)
  25. Samsung Galaxy S21 / S201 Ultra phone owners report a lot of problems with BT disconnections in general (not only with Garmin products). The phones seem to suffer from conflicts between the WiFi and BT. Try turning the phone's WiFi off to see whether it is your case too. If it helps, then try using a 5GHz WiFi instead of 2.4 GHz. Report the issue to the Samsung Support. (source 1, source 2)
  26. Google Pixel (and many other Android brands) cope with BT connectivity problems because of the battery optimizing feature called DOZE. Read more on the topic, and on the way to disable it:
  27. Google Pixel owners report serious BT problems with some OS versions, telling an update to v13 fixed it (at the time of writing v13 was in the beta phase). Otherwise, turning off the WiFi on the phone, allows using BT correctly. See the threads Does Garmin Connect work with Android 12? and Instinct 2 (Solar) constantly disconnecting and connecting till phone restart (Pixel 6 Pro) for more details.
  28. Enabling the new "Gabeldorsche Bluetooth stack" option in the developer options of the phone fixed the BT connectivity problems too, on some phones at several users.
  29. App Overlays (i.e. Skype, FB Messenger, WhatsApp, etc. use them) may pose a problem on some models of phones, as reported in this thread. Read the thread if you do not know what App Overlays are, or when you want to learn how to disable them.
  30. Check the changelog of the last OS update of your phone, or contact their support to find out which of the changes of their software could have led to this outcome.
  31. If nothing helps and you know the previous version of Garmin Connect Mobile worked all right, consider installing an older version  from an APK archive. There are several unofficial APK archives available on the web (for example here). Use on own risk - there is no guarantee from Google or from Garmin that those files were not modified by a 3rd party (though I have only positive experience with the mentioned website)
  32. And of course, if nothing of the above helps, and you did not do it yet, then contact your local Product Support - they may be able to give you additional hints, or may be able to analyze the logs on your device, and find the culprit.
Happy Syncing!
Top Replies
All Replies
  • My F6X stopped syncing with my Pixel 2 some days ago. What fixed it for me was clearing the cache of the Garmin connect app.  maybe it would be worth adding clearing the app cache also as one troubleshooting step.
  • Thanks! I added it as #6
  • Good day,
    I would also like to contribute my experience with pairing watches.
    I struggled with garmin connect mobile for 11 whole days before I solved the connection. First, I had to get unofficial android 12 on my old phone, for which android updates are no longer released, at this point my watch started to communicate at least with bluetooth on the phone. So for me, it was first necessary to pair the watch with the phone (not with the application) and then only in the application, which, however, could not be caught from the beginning and the pairing was cut in 1/5. The fact that I managed to fine-tune the pairing afterwards with the application was about fine-tuning the correct access of the application's permissions. I have enabled all garmin mobile permissions except for positioning, in my case this must be explicitly disabled, otherwise it will break the pairing or then the synchronization. Furthermore, the same effect also applies to Wi-Fi in my phone, it needs to be turned off, otherwise pairing and synchronization of paired watches will be interrupted again. So, if someone struggles with pairing like I do, I recommend first, if you can pair the watch at least with bluetooth on your phone, to try granting permissions to the application using the exclusion method, while leaving WIFI off. Or, after that, go to such a radical approach as rooting the phone and playing an unofficial system. (For me, it didn't even matter if the WIFI was connected to 2.4 GHz or 5.8 GHz) So I wish you a lot of success and strong nerves for the new year. David
  • Thanks for the tips about the pairing! However, pairing is not at all covered in this thread. It is a different topic, and would require a separate thread, to avoid cluttering the connectivity troubleshooting guide with paring problems.
  • if you can't pair, you won't even sync, that's how it works for me, if I disable location and wifi, sync resumes after a while, I thought I was in the right thread, sorry, if possible move the post to the right thread
  • Yes, exactly, but there are many other possible problems at pairing. I do not want to clutter this guide with pairing issues though, because it is already long enough as it is, for people to run away scared. Having the phone paired is the basic prerequisite. There are already many threads in this forum, discussing issues at paring (here an example search query), so it might be better posting the information there. People will find it easier there.
    Even better would be writing a similar guide for pairing issues too, and have it pinned to the top of the forum
  • Hi, I have a problem with my garmin foreunner 245 music when trying to download a podcast via spotify on my watch. It always fails to sync when a podcast is over 60 minutes long. Its nit a matter of capacity, because when I download 3-4 podcasts 60 minutes long everything works great, but when syncing a 90 minutes long it stops at 70-80% and crashes. Does anyone know how to fix this issue?
  • Spotify is really a completely unrelated topic, so I can only advise to launch a new thread, or using one of the numerous existing threads on that topic. Some basic troubleshooting tips are also available on Garmin's Support website: I Am Having Issues with Spotify on My Garmin Watch | Garmin Customer Support
  • I've had a problem syncing my Forerunner 245 with my Sony Phone, which has worked seemlessly for two years.  I did a run last on a Monday night 10pm ish , that ended 00:05 Tuesday am, prior to leaving, say 8pm, my watch flagged up I had hit the 10,000 steps mark.
    After the run, I synced my watch before heading home.  Other data (steps, heart reate etc appear on garmin connect up to about 6.30 monday).
    The run data is there, appears fine on strava and in Garminetc. BUT:
    Training effect was very low - 1.4, for a 12km trail run.  Typically I would expect this to be 3.5 or so.
    Looking at intensity,on my daily summary for Monday is says zero, for Tuesday is says 16mins (I believe this is last bit of run (the bit on Tuesday), then walk to car).
    My step count chart in connect is only goes up to around 6pm Monday, there is no data from then until early tuesday morning.
    On my watch, step count for monday appears correct (c21k steps), and intensity minutes seem ok too, taking into account the run.
    I've synch'd multiple times, I've reomved and reinstalled garmin connect, restarting watch and phone, and I've sync'd via Garmin Express.
    I'd like to get the missing steps, and intensity minutes correct, (also calories data doesn't seem to have taking into account the late run, nor has body battery (it slowly recharged whilst I was running).
    Any one got any ideas? Otherwise this is a sad end to a long step count streek.
  • Since the syncing seems to work, it looks rather like data corruption, or misaligned or multiple Garmin Connect accounts associated with the watch. Check the  Troubleshooting guide for (some) data missing after syncing for some tips.
