This update can be downloaded with Garmin Express or automatically with Garmin Connect Mobile.
Change Log
- CIQ security fix
- Resolves USB connection issue with 9.60
Change Log
In our internal testing, we have seen the best results by following the steps below to update with Garmin Express.
Absolute rubbish, this is the second update that just makes things worse. After following the Garmin advice I lost correct date and time. This is the first time that has ver happened. Had to stick the…
After the update to 9.60 the watch was having difficulty synchronizing with the PC via the USB cable and I verified that the time was not correct when set in auto-definition ..... with 9.70 the connection…
Have applied the 9.70 firmware update; seems as if my 735's issues have been fixed and everything seems to be back to normal.
Thank you.
The drivers are baked into Garmin Express so there is nothing additional to download or install. If you follow the instructions in the link below, does this help at all? I understand you haven't described a freeze exactly. 5310691
https://support.garmin.com/en-US/?faq=1mUvijnL4C8jZ2DxYa1Mw7&productID=541225&tab=topics
Here's how I applied my update - maybe this will help:
First of all, Garmin Connect (= the mobile app) was unable to 'see' the new firmware. This means that you have to use Garmin Express (the PC/Mac) app for the FW update. For me, it was not necessary to reinstall Garmin Express. All I did was:
In comparison to other previous updates, this process DID take longer than usual. HTH!
