Has anyone else had a problem with connecting sensors since upgrading to version 12.30 I can no longer connect my Edge remote or Cadence sensors
Hello everyone,
We have released Official software version 12.4 for the Edge Explore 820. It will revert back to previous software while we investigate reports of sensor dropouts. It can be found at the…
We are actively working on a resolution. I apologize for any inconvenience this has caused and I will update the forum post when we have a resolution.
Hi Garmin Matthew, can you tell us, when we can expect an new error-free update for our Garmin 820? 1 day, 1 week, 1month? It would help us in our decisions.
We all have problems with our units falling out. Power, cadio and radar ...
just upgraded my 820 to the 12.3 version today. went for a ride and the speed and distance did not record but the elevation recorded correct (i was able to double check as i had intended to do a data comparison and by chance recorded the ride with another device too)
Yo lo he solucionado a medias cambiando la configuración del siguiente modo:
Configuración-Sistema-Gravación de datos-inteligente
Con la grabación de datos en 1s perdía con mucha más facilidad los sensores. De esta manera he podido grabar una sesión entera de 1h. sin aparentes pérdidas de datos. Falta ver como funciona en las siguientes sesiones.
Yo también he vuelto a tener problemas pero he podido grabar sesión con todos los datos después de deshabilitar el Wiffi y el Bluetooth antes de empezar la actividad.
configuración-sistema-wiffi-desactivado
configuración-sistema-bluetooth-desactivado
No es cómodo porque cada vez que quieres subir la actividad has de volver a conectarlos pero la actividad registra todos los datos.
Check out my mountain biking activity on Garmin Connect. #beatyesterday
Today, heart rate sensor and cadence disconnected and reconnect after update 12.30.
