New Edge 1030 Public Beta 9.68 Now Available
A new Beta software for the Edge 1030 has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
Edge 1030 (9.68): https://www8.garmin.com/support/agree.jsp?id=12819
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 9.50 to 9.68:
  • Segments:
    Fixed issue with detecting segments that were going in the opposite direction of travel
    Improved segment and ClimbPro UI cooperation
    Fixed issues when approaching a segment embedded in a course and other minor segment UI issues
    Fixed issue where segment virtual partners would claim to be finished almost immediately after starting the segment
  • ClimbPro:
    Improved estimated time to end of a ClimbPro climb
    Fixed ClimbPro page graph drawing
    Fixed issue where disabling 'Pop-up on Climb Approach' would disable ClimbPro completely
  • Improved iPhone pairing
  • Improved sensor connectivity
  • Improved automatic FTP detection
  • Added Go Back, Pause, and Go Forward workout step controls to the workout tray
  • Added support for new GPS firmware. Sync your device to update to the new firmware
  • Added option to delete a data field in quick edit mode. Access by pressing and holding a data field on a timer page.
  • Improved grit and flow consistency between Garmin products
  • Improved bike light connection stability
  • Fixed bike alarm not turning off after correct password was entered
  • Fixed radar vehicle drawing temporarily not updating
  • Added a shortcut to the display menu by pressing and holding the Auto Brightness button on the status widget
  • Added a toggle for MTB map theme
  • Improved MTB trail search UI
  • Fixed issue where history line wasn't updated while panning in the map
  • Fixed issue with the number of power zones displayed post ride
  • Fixed dual sided power meter calibration factor reporting only one side
  • Fixed Firstbeat metrics for multiple rides during the same power cycle
  • Fixed Training Effect UI layout
  • Removed unnecessary beeps for notifications that don't need them
  • Fixed timezone map downloads from WiFi
  • Fixed issue with power targets in TCX workouts
  • Made various device stability improvements
  • can you check also elevation gain vs other friends elevation?
  • So I've done two rides with the 9.68 beta now. Overall as long as you don't have WiFi & BT on at the same time (which causes the edge to lock up) the build has been pretty stable, with no reboots or power-off's experienced, which is an improvement on previous builds
    It looks like the Radar bug has been fixed where a ghost vehicle detection would be displayed right behind you when a new vehicle was detected. Also the workout rename bug I was experiencing seems to be fixed too.
    There are however some issues with the beta
    > The Edge Remote bug has reared it's head again. During the ride the remote will randomly disconnect & on resuming from sleep the remote won't connect unless you disable/enable the remote in the sensor settings.
    > The Map display & navigation popups are pretty laggy with this build......
      > The fix that was supposed to have been implemented for the history track not updating when panning the map doesn't work. In fact it's made panning worse as now when you pan the map, the map itself quite often doesn't refresh leaving a blank area of map or worse still will just flicker like something is being refresh but doesn't display anything, certainly not the map
      > The navigation turn prompt popup regularly just displays a blank map instead of the turn or displays the map after you've made the prompted turn.
      > On the map screen, when navigating; pressing the area showing the next turn at the top of the screen brings up a list of the upcoming turns & you can select to preview a map of the turn, however more often than not the map showing the turn doesn't display & when it does it may be a number of minutes before it actually displays it.
  • From this point I am also happy, I did yesterday an 6 hour ride with no issue ,I did not use TBT
    Also from release until now I rode ~350 km  , with no freeze
  • many dropouts of speed, heart and radar sensor.
  • Former Member Do you know if the crashes caused by BT/WiFi have been fixed between 9.68 beta & official release of the 10.00?
  • only time, and Garmin developers knows :)
  • I installed version 10.00 yesterday. The device was frozen at main screen looking for wifi connection. Touch screen was not responding. I could reboot It pressing on/off button for several seconds, but I reached again same condición.
    Previously I was using v9.68 with no wifi issue.
    Finally I solved it connecting the Edge to my Mac. Synchronization worked fine and dismounting the device makes it boot normally. Then you can disable wifi connection and all works normally
    I have done a 50 km ride today  with no issue except sensors disconnection that has happened twice for a short time.
  • Thanks for the info. I installed 10.00 via Express earlier today & have since enabled WiFi & BT with no crashes or lockups. I've also connected it to my laptop since & it transferred into Mass Storage automatically, again without locking up. I haven't been on a ride with this build so I'm not counting any chickens just yet
  • yeah, 10.00 upgrade today for me.  I've always left WiFi on, but long ago removed it's association to an SSID.  This is the first upgrade in a while since 9.x where I haven't had to go through some heroics to get it to boot after upgrade.  So far so good.  Smoother than the 9.68 upgrade where I initially had a bootloop.
