During the last night's this is what my HRV readings look like.
The data is getting inconsistent because of this. Is anyone familiar with this problem and might know of a solution?
All,
Thank you for sharing your concerns regarding HRV gaps. We are still investigating reports, but have still determined that the gaps are due to restricted blood flow. In case you missed my comment…
This is what Garmin has said about the problem on the bug report thread (forums.garmin.com/.../18-15---intermittent-hrv-measurement):
"We have been investigating similar reports and have a fix coming in…
All,
If you are experiencing this, please respond with the following so I can add you to our investigation:
1. May I have permission to reach you via email?
2. May we have permission to view your Connect…
I have the same issue. Reset didn't help :-(
As visualization and to state (again) that this has nothing to do with laying on my arms while sleeping some more pictures of my last few nights:
Until some weeks ago there was a brief period in which this didn't occur while it did before, but it's worsening A LOT lately.
I paid a lot of money for this watch and its functionalities, but now it's almost useless. I like to use the functionalities, especially since I'm running a marathon in 4 weeks and it would have been nice that this would have been working.
Now all I constantly see is that my HRV status is unbalanced which is not correct but is obviously caused by these bad results.
4605486 which is obviously not true since it's a software issue. I had contact with Garmin Support and they told me the following:
"We have a fix for this disruption, but it will not make it into the Q1 2024 software update. We hope to have this fix released for the Q2 2024 software update.
As a workaround, users can try wearing their watch 1 or 2 notches tighter. They should not be able to see the green OHR lights unless they lift the watch casing to peek underneath."
So the fix is to stop the bloodflow to your hands and slowly let your hand die during the night, haha.
But on a serious note, Garmin-Sierra please give us the exact timeline on when the fix is going to be released. It's a big shame that this already lasts for months and still doesn't get fixed.
I have a new watch, almost a couple weeks now. I have very minimal gaps, most nights maybe are missing one little bit (like 20-30minutes) or zero gaps I can see. However one thing I notice... the screenshots I see on this post all have HRV of 110ms-160ms. I know everyone's HRV is uniquie and different highs/lows... similar to someone's Max HR or Resting... BUT... mine NEVER is above 100 for avg, maybe once 105 as the Highest 5min, typically in the 40-65ms. I don't know the range of HRV in milliseconds, but makes me wonder fi at a certain higher value the watch thinks its missing readings or out of range?! Just a wild guess? EDIT: Now looking they are all Jasper screenshots... so maybe not a pattern. Other people have high values that are having this issue?
Anyone getting many gaps that have readings in the 40-70ms range Avg typical and 'Highest 5minute' value of 70-90?
The times this had bugged my watch the HRV with the gaps had been on the 60-70 range. However, it's more than my usual HRV and I've noticed that often my nightly HRV values had started to rise (against my expectations) already a night or two before the gaps.
For me a force reboot has always solved the problem. It's like the sensor starts to "drift" towards higher HRV values and then the gaps appear.
This comment resonated with me. I noticed that my HRV, too, was suddenly much higher recently and then the gaps in the overnight timeline appeared. I doubt it has anything to do with sleeping on my arm because I've been sleeping in the same way for years and the overnight HRV tracking worked fine before. Garmin-Sierra, you are welcome to contact me via email and/or review my Connect account.
