During the last night's this is what my HRV readings look like.
The data is getting inconsistent because of this. Is anyone familiar with this problem and might know of a solution?
All,
Thank you for sharing your concerns regarding HRV gaps. We are still investigating reports, but have still determined that the gaps are due to restricted blood flow. In case you missed my comment…
This is what Garmin has said about the problem on the bug report thread (forums.garmin.com/.../18-15---intermittent-hrv-measurement):
"We have been investigating similar reports and have a fix coming in…
All,
If you are experiencing this, please respond with the following so I can add you to our investigation:
1. May I have permission to reach you via email?
2. May we have permission to view your Connect…
I have the same issue. Reset didn't help :-(
Hi Everyone, here is the response I got from Garmin so I would not hold off on expecting a update to fix the HRV gaps:
"Thank you so much for doing the logging! After investigating your logs among other affected devices, our engineers have determined that the HRV gaps occur when users are laying on their arms or the device. This restricts blood flow, leading to a deterioration in the OHR signal and affects HRV data. We can only encourage users to take possible necessary steps to avoid sleeping positions which may lead to this outcome. Let me know if you have any questions or concerns regarding this consensus and conclusion of the investigation".
Thank you for sharing, 9992663.
To add to that statement, we are still working on general improvements. If anyone has any further concern, please reach out to Garmin Product Support directly.
Garmin-Sierra Somehow you try to put this problem away as sleeping position, but my last nights and especially last night show this is definitely NOT the case. This problem is now ongoing for several months and still no fix at all:
Hi Garmin-Sierra
, see picture attached of last night. Problem is obviously worsening again: (even on 19.09)
