Anyone else getting random freezing? Only started this week but twice now I’ve looked at the watch to find it’s still showing an old time. On closer inspection the whole watch has frozen and all I can do is a reboot.
thanks
All,
Thank you for your discussion and contributions in this thread. We do have formal reports of this submitted directly to Garmin Product Support and are currently investigating. When we know more or…
All,
If you have not been contacted regarding this, you will need to reach out to your local Garmin Product Support agent.
4774293, I will message you directly so I can make sure you have the correct contact…
**Update**
starting to think it’s heat related. I’m in UK and currently around 30C. Just happened again in quick succession. Turned it off using the long button press but wouldn’t turn back on. Dipped…
Same for me since today, two times (or at least similar behaviour). FR955 non solar. The watch face freezes (seconds stop counting). But I do not need to restart the watch; once I push some key seems that…
This appears to be an overheating issue as far as I can tell, as my 955 Solar freezes in the following situations:
Regardless what time it actually freezes, I usually lose most of the data gathered since the last time I synced with the Garmin Connect mobile app. This sometimes means losing a few thousand recorded steps, or not getting any HRV tracking while sleeping. The battery drain during that frozen period is usually significantly higher than during normal operation.
The solution is to either wait, or run some cold water over it for a minute, then doing a reset (hold power button for 15+ seconds), then briefly connect to a power source. Sometimes it takes multiple attempts to turn it back on, but it does still take a charge from the power source while trying to resurrect it.
I got mine at the end of October 2022 and started noticing this about a month later.
Yes, yes, South Africa.
