Firmware Update 11.12
Anyone have this available?
  • This is my mistake. You can still swipe away notifications. The "swipe away" gesture now needs to be done over a longer distance, starting closer to the left of the watch face.
  • Schnellejugend mine only came through 12 hours ago, had auto update selected, then turned on WiFi and connected several times then it popped up. It might be because it's slowly downloading to your phone first.
  • I found another bug with 11.12:
    When I start the "LAST ACTIVITY" in the Glance menu not all activities are shown in the list. When I connect the watch to the computer, the activity .fit files are in the /GARMIN/Activity folder. After I start the Garmin Express all of the previously stored activites are gone from the folder and the "LAST ACTIVITY" list is completly get confused.
    Can you check your "LAST ACTIVITY' menu, your list is correct?
  • Not noticed it here (just tried). Have you turned the watch on and off? I had issues picking a sport last night and wrong one coming up eg breathwork was run and hrv was walk, but after turning watch off and back on it seem to solve things.
  • i had a strange battery change after updating. i charged it to 100%, it dropped to 99% in 1 hour, then dropped to 97% after a total of 5 hours. out of curiosity and concern, i restated the watch (held power for 15 seconds and then rebooted). it came back on at 99%. now, overnight, after a total of 17 hours, it's at 97% which is pretty normal from my 5+ weeks of experience with the watch.
  • Wondering, anyonne have the 10.10 file for the 955? I want to rollback.
    0 Former Member over 3 years ago
    Auto detect max hr still broken.
  • cautious hope!...
    i just went on a run and at the end of the run, i consciously tried to trip up my watch by paging quickly to the maps page and low and behold, it didn't crash and displayed the map!
    so, it's 1 for 1, but this gives me some hope that things are little more stable. i'l be curious to hear if any others encounter map crashes with 11.12.
  • I now have the "tap the map and it moves in a weird direction" problem since the update. (Also known as the Greenland problem.)
  • i think we all have this problem. but i'll take that (for now) if it doesn't crash on me as the workaround is to pan around using my finger and then using the buttons to zoom in and out.
    not ideal, but less ideal is when the entire watch crashes Stuck out tongue
