here's the picture I was referring to:
Thanks
Thanks
The red is active calories burned when you are exercising or moving.
Hi, yes the red peaks are active calories and I suppose the scale on the right side of the graph from 0 to 30 should be representing the red calories values.
I just wonder how we interpretate the resting calories (blue portion): if there is no scale for it what's the sense of the graph?
I replied on this before in your other post, take your resting calories / 240 and see if it works. Mine does. Indicating that each reading is for 1/10 of an hour , on the same scale
My resting calories per day is 1838. If I divide 1838/240=7,65 that is higher than you can see on the graph (less than 7,5)
Well, then each reading is probably 5 minutes (1/12th of a minute). Then 1838/(24*12) = 6.38.
Thanks, but unfortunately still not. In the afternoon it's quite 10 ! Very curious. Still 1838 calories at rest!
