I have a Forerunner 255 and I recently run a with a friend with Forerunner 265, after 10km there was difference around 900mt. Any suggestion?
Thats strange , mine have always been very accurate across devices. Thats a 10% difference.
Are you using the same GPS type settings?
Did a proper lock on at start result?
Look at the maps , can one see a difference? That may help isolate the reason.
One isn't using an HRM with "indoor only" not activated?
Can you establish which is correct using a map / prior runs?
Thank for your attention.
The GPS setting is automatic selection for both, the track is the same, we start and finish at the same time and we run side by side for all the track. The only differences are: I run with HR Garmin Pro-Band (Forerunner 255) and my friend as followed a training 10km in a selected range.
