This is the 2nd time this has happened since getting the watch less than a month ago. Normal drain is about 2% overnight. I have shut-off WiFi, which I thought was the culprit after the first time. This problem has happened twice now, randomly. The drain DURING activity seems to be in line with Garmin battery assumptions. So, it's the General Use of the watch that is the problem. Maybe occasional overnight updating via BT? Or constant syncing via BT? Or BT gets 'stuck'? Any thoughts before I contact Garmin Support?
