Recover HRM pro data after watch crashed
My watch (enduro 2) crashed at the start of run and rebooted a couple of times. When I finished I saved the activity (4 secs long) is there anyway I can pull the heart rate etc. Data from the strap manually make the run with the data ?
Top Replies
All Replies
  • Probably you should get HR data from the strap synchronized it with GC on your mobile.
    Rest probably gone.
    [deleted]
  • Hi,
    Thanks for the suggestions.
    I had a similar idea when I posted so this is what I've done. Unfortunately doesn't seem to have worked Disappointed
    First I synced HRM to Garmin connect, that saved my steps and heart rate .
    Next I went on Strava and downloaded a fit file from a guy I finished a few seconds ahead of.
    Then I uploaded that to Connect and imported it into my watch .
    I then went onto the watch and selected the activity that I had imported and pressed download HR. It searches ,downloads but it seems to get stuck on processing Downloaded HR data . I've tried a couple times and it just spins and spins .
    Guess it's not possible:(
    0 Former Member in reply to cloc
    [deleted]
  • Thanks for all the help.
    Do you think I should edit the fit and attach the serial number of my device ? Or my heart rate strap .
    I do have the hrdata.fit should I try combine the files together with the activity file on a site like gotoes
    [deleted]
  • I will happily send you the file of the activity ive uploaded into connect and the HRdata file for you to have a play with, no idea how to do this though as this site doesnt allow sending fit files.
