I have lost a tempe sensor on my lawn.
If I look for it with my 945, it detects it and reads its temperatures, but I can't find it. Is there a system to locate it with the approximation of less than one meter?
Do you have access to some black plastic sheet for more low-tech approach?
On a sunny day lay the sheet on the lawn in your 10m x 10m target area and see if the temperature from the Tempe rises. Give it…
I found it ! It was in a bush in the meadow, as I feared. I used a metal detector that detected it! If I calculate how much I spent on it, I would have bought 10 Tempe !! But certain satisfactions are…
Use a metal detector. Some places allow you to rent one per hour.
Well, at least in theory you could move in one direction until the Tempe is out of range (very slow, since it only transmits every 1-2 minutes). Then move back and in another direction until the same happens. After you've done this in a couple of directions, you could try to pinpoint a point on your lawn that is equidistant from each point where the Tempe gets out of range. Whether this is practical, I'm not so sure...
Thanks, I have tried this strategy, but it is approximate and I have circumscribed an area of about 10 meters by 10 meters. It is definitely within this area, but I cannot find it. I need a more precise method, maybe, if there is, a frequency detector with power meter. Is there something of this ?
On a sunny day lay the sheet on the lawn in your 10m x 10m target area and see if the temperature from the Tempe rises. Give it 10 minutes or so. If the temperature doesn't rise then move the sheet.
If the temperature rises then fold the sheet in half and see what happens. If the temperature is stays up then it is under the sheet. If the temperature falls it is in the area you just uncovered.
Start with a large sheet to find the general are where the Tempe is. Then halving the area covered by the sheet with each repeat can very quickly reduce the final search area.
If no temperature increase is seen within say 10 minutes move the sheet to a new area and monitor the Tempe.
I used forced temperature changes to find a Tempe I lost in the house.
Thank you for your suggestion. But I think I will need white material because when it's sunny the lost tempe marks values between 40 and 50 degrees. Covering it with a white sheet I should be able to lower the temperature. But there is another problem: there are also small bushes in the lawn and I would not like the mower have "shot" the tempe right inside them. And is really difficult cover the bushes! It's a real puzzle !!
