Hello.
I havea Fenix 6 and today I used for first time HRM Pro.
I paired my watch with the strap, I start Strength Activity and I put out the watch from my arm.
I began the workout and at the end when I stopped and saved the activity I noticed that they are gaps on the heart rate.
These gaps are the moments that i was running outside, and I wasnt close to my watch (not within 3 meters).
I read that there others that have the same issue.
Also, when I connect HRM Pro to Garmin Connect, the sync fails.
Is there any solution? Should I try remove and put back the battery?
Thank you.
