Garmin HRM-Dual not working after less that 1 year. Should i change the battery? The spec states battery should last about 2-3 years. Any advice?
We recommend replacing the batteries & performing a reverse polarity on your Heart Rate Monitor (HRM) by following the steps below.
Please follow the steps below to perform a Reverse Polarity on your…
Exact same issue here, and it used to work fine. Now it connects, shows say 72bpm for a few seconds, then nothing more. Have done the battery-flip reverse polarity solution, no joy. This is also with a…
Mine show 72bpm and stop.. done this procedure and now doesn't connect to my edge.
Quite disappointed
Yeah, the reverse polarity thing is bogus. There is zero chance the engineers didn't include a diode. It's more likely just the reset from a full drain (battery out for 30 seconds) that reset it.
New battery fixed the issue for me.
Good to know, i will try before throw the thing out of the window
Too late for me. Replaced the battery, left battery out long enough for capacitor to drain. Shorted the battery terminals (battery upside down for ten seconds), washed the strap in the washing machine. All to no avail. I saw a replacement strap for $30 online, but since they couldn't dane to make the HRM-Dual work with their connect app, I feel too singed to give Garmin more money. One to try a cheapo strap and see what happens. Good luck to you.
This worked actually
HRM Dual is very sensitive to battery voltage. And don't assume a new, even brand-name battery, is not already below voltage. I just tested 4 new batteries with a multi-meter and 3 were already at 2.5V - should be at least 3.0V! Only one worked in the HRM Dual, at 2.8V.
Yep! This worked. Old, beat module that I thought for sure was NFG, but it lives on!
Thanks, this was my problem. I replaced the battery and the monitor worked for 30 min. Measured my "new" battery and it was 1,9 V. I bought a new one and everything is working fine now.
This worked for me!!! YESSS!!!!! I bought new batteries because I thought the ones I had had gone bad over a year but turned out it was the reverse polarity trick that did it
