Since the update I have to tap VERY hard in order to n the light on (Vivoactive 4s). Sometimes it takes 2 or 3 hard taps. What’s going on? It was always just a slight tap/touch to turn it on. Not anymore.
All,
This has been resolved with the software update to 6.80. If you are experiencing issues after installing the 6.80 update, please start a new thread.
Let me add that all the swiping through menus works just fine with the same sensitivity as always. It’s just to activate the backlight that now requires quite a hard tap.
Same here. I have 6.50, and trying to turn on the backlight with a tap is now much more difficult. Most of the time, it WON'T COME ON AT ALL anymore until I press a button. No matter how many times I tap or for how long, it won't work.
I'm trying it right now. I cannot get the backlight to come on with a tap. I have to swipe.
That's weird, I can enable a backlight with a tap most of the time now, but it's still the pain to turn off the timer.
I agree. Whilst there is a change for me it is 100% workable more of a touch than a tap works every time for me and reduces the chances of the backlight coming on in bed & using battery. I actually believe it's far better than the tap for that reason.
For me at least I don't have to tap any harder. I just have to hold the tap slightly longer. Personally I love the change. Since the update I haven't accidentally turned on my backlight while trying to get to sleep even once. Sure it took a bit to get used to needing to touch the screen slightly longer to get the backlight to come on, but the trade off is well worth it to me.
It would appear that the update to 6.80 has reverted to the previous level of touch screen sensitivity ? This means more risk of accidental backlight activation with consequential battery drain.
After initial issues with fast battery drain on 6.50 it has been the best software version for me since I got my device. I do appreciate that others may have experienced issues in areas I likely do not use so a fix may have been required.
