Venu 4 again frozen and inaccurate heart rate
My watch froze again. Now after 38 minutes of a runnining workout. Before it did it was showing an inaccurate heart rate (constantly around 150 when I was running and then 170 when I took a walking break).
Is there a solution to this?
These are basic functions which should work flawlessly!
After many years with Garmin I am considering to return my watch and give a competitor an opportunity.
Please fix this asap.
  • Same here. Every run with Spotify the watch freezes. And Garmin wants to waste my time by offering an exchange of the watch instead of releasing a software update or communicating transparently about it.
  • Myslím si, že  garmin veřejně nic přiznávat nebude. Byla by to jejich velká ostuda. Proto mlčí a nevyjadřují se.Neví se s tím rady. Pokud je to softwarová chyba tak by vydali aktualizaci, která to opraví. Možná to je hardwarová chyba. Mně to po výměně hodinek při aktivitě nedělá, ale má to určitě souvislost se spotify přes sluchátka.
  • Same here, run coach, Spotify and headphones --> watch froze (sw 14.12). It's my first Garmin watch, not sure if it was a good decision to switch to Garmin.
  • I have the same problem with my Venu 4. The watch crashes during a running activity. I always play music (Deezer) through the watch during the activity. This is really frustrating for such an expensive watch. I hope a software update will be released soon. I can therefore only advise everyone not to buy a Venu 4 at the moment until this bug is fixed.
  • @garmin support team,
    Is there any update for this error?
    When can we expect a software update?
    It is unacceptable that even basic functions of the watch do not work correctly and that customers are forced to serve as beta testers.
  • I fully agree. For me, the option to store music and podcasts on the watch was the main reason I chose the Venu 4 over the Suunto Race 2.
  • Still not solved as far as I see. They just recommend useless steps as restarting the watch or replacing it while they know that only a software update will help. @Garmin: Any update?
  • Anyone having the issue after updating to 15.16 which just came out?
  • Oui malheureusement
  •   , this error still exists! Even with version 15.16. When will this problem finally be fixed?
