Garmin-Kevin you have locked last discussion promissing a new update cominng by the end of q3 update cykle. We are at the end of Q4 and there is still no FW update. Any new information you could share with us? Thanks
Please see the 3.00 software update for this device which was just released and addresses this disruption. This software release should be available to all users at this time.
If you are having difficulty…
Can someone at Garmin respond to all our shout outs.
S2 Body Fat not accurate - Index S2 Smart Scale - Health & Wellness - Garmin Forums
We are aware of the issue and…
Well.. let's be realistic... do they want to spend time maintaining software on a $150 scale or a watch that costs between $1000 and $2400 ?
Realistic? My $1500 watch and $1000 Edge…
What am I doing wrong here?
You've bought the Garmin Index S2.
My Tanita reads 13.6%. Before the upgrade S2 was reading 16.5%. After the upgrade S2 jumped to 22%. After I updated the body composition correction factor to 13.6%, the S2 now says I'm back to 16.4%. I'm not sure what the update accomplished - but improved accuracy definitely wasn't part of the update. Perhaps Garmin could add a daily physic reading feature if the S2 is just going to make things up.
Yea, i don't know what the point of that update was.
Question, what is the "body composition correction factor"? is that something you can change? I'm just fiddling with age and activity level to get the body fat to be at least close to accurate.
At least you can use your S2. The update effed up its Wi-Fi connection. Now syncing is impossible. Nothing works. lol
Not everyone is affected, but we're pretty much effed.
As for body comp correction factor: You can now enter calibration values in the Index 2's settings (GC).
this morning it gave me 8.1% so thats pretty close to the 8% it "knows" as fact, yet its crazy that it immediately gives a variance and others are still getting bigger variances.
30.9kg muscle, 5.1kg bone and 67.1% water so its still allocating most of the reduction in fat to water and a bit to muscle and bone.
statistics suggest my bone mass is likely 2.5-3kg so it is interesting for garmin to say twice that, especially since we believe these scales to be heavily based on statistics. i think it is clear that 5.1kg is not possible
water% is plausible but this is highly variable
adding together the composition components gives a total mass 24% higher than the actual but thats not unusual since muscle contains a lot of water so it can be counted twice
FWIW my 8%BF is very conservative - i pulled out the old scales i used to use and they give me 6.6% which i have reason to believe is reasonably accurate.
at least they are now starting to use "estimate" in their wording
