Garmin-Kevin you have locked last discussion promissing a new update cominng by the end of q3 update cykle. We are at the end of Q4 and there is still no FW update. Any new information you could share with us? Thanks
Please see the 3.00 software update for this device which was just released and addresses this disruption. This software release should be available to all users at this time.
If you are having difficulty…
Can someone at Garmin respond to all our shout outs.
S2 Body Fat not accurate - Index S2 Smart Scale - Health & Wellness - Garmin Forums
We are aware of the issue and…
Well.. let's be realistic... do they want to spend time maintaining software on a $150 scale or a watch that costs between $1000 and $2400 ?
Realistic? My $1500 watch and $1000 Edge…
What am I doing wrong here?
You've bought the Garmin Index S2.
Can we come over to get our readings?
lololol. I have both scales side by side so will see how they are tracking together. I think Garmin finally listened - I think their sensor is ok, its just an algorithm issue and I think having someone put in a Dexa (or other scale) is probably as accurate or as correct as any algorithm out there.
If you are having difficulty with the update, please see:
i just tested it. i set my BF at 8%. immediately got a reading of 8.7%BF from the garmin scales. this is a whole lot better than the 15% it had been giving me but there is some interesting logic going on there to take the baseline and immediately decide it knows better!
unfortunately having been relying on the garmin scales for 2 years now i don't have an up to date BF% but believe 8 will be pretty close
the 15%BF reading has 31.1kg muscle, 4.6kg bone and 62.2% water
the new 8.7%BF reading has 31.3kg muscle, 5.2kg bone and 66.6% water
so the big reduction in BF seems to have mostly been reinterpreted as water. i would strongly suspect that a fair chunk of it should be muscle (other readings from 2 years ago support that). worth noting that the first weigh-in was my normal first thing in the morning whereas the 2nd was afternoon so reasonable that water% increased but if nothing else, we've lost 6.3% and added back 4.4%
so initial impression is dubious but it is at least an improvement
Just updated so 3.00, the scales show my body fat at 22.1%, while my actual body fat is 7.6%.
Updated my body composition values, Garmin shows 9.9% BF. My guess is that Garmin's algorithm is still based on user's age, sex, weight and height alone, except now the values are adjusted to be closer to the ones entered manually.
To be honest these changes look like "we're still not really "measuring" BF% but now we're making the users enter actual values themselves to help us hide this fact".
