Hi I’ve updated my edge 830 and it’s turning off and on mid ride. Is anyone else experiencing this?
Is there a fix?
Thanks
Is there a fix?
Thanks
All,
I'm currently waiting on a reply to see what information I will need from you. Once I hear back, I will update this thread.
Please reply back with a Yes if I can email you directly.
I am facing the same now as well. My Garmin is restarting on almost every ride. Anyone found a solution to it?
You can email me directly, yes
Is anyone still having the problem? The firmware is the latest 9.75 and it switched off twice during my ride today which was very annoying. I’m not sure I want to do a factory reset although will if it fixes it.
Yep. Reset does not work. I think Garmin has moved on…I wonder if the 840 does it too?
I have ridden very little lately - my unit has not stopped mid-ride, but it has as I was pausing at a coffee shop. So i believe the issue persists.
I got an email from Garmin with a ton of questions, and instructions how to upload data for them to check.
But honestly... - It's not my job to do that. FIX YOUR PRODUCT - i'm not your software engineer. Just fix it. Dont waste my time. I'll probably switch back to wahoo next time.
Mine happened after a cafe stop too. It started ok then stopped after about a mile. It happened again about 5 miles into the new ride. It’s very irritating. I might just go back to using my watch and phone if I need to navigate.
I have the 830 and ride with a friend who has the 1030 they have both had this problem since new. I assume the whole range has the same problem. At this point I am assuming Garmin will never fix the problem. I have seen it suggested it is linked to using the Live Track feature which we both use but have never tested this theory out.
I gave up on the 830 because of this issue and bought an 840. I figured if the 840 does it I can just send it back under warranty. The 840 does not do it and I have the identical setup as before. Really irritating that garmin can’t fix the 830 as it worked fine for years.
Keep us posted. I am really by it, and I am considering a switch to Wahoo.
Happened to me yesterday. First the HR sensor stopped then the screen went blank. I restarted and was able to save and restart. Pretty poor service from Garmin who havent fixed in over a year.
