Hi I’ve updated my edge 830 and it’s turning off and on mid ride. Is anyone else experiencing this?
Is there a fix?
Thanks
All,
I'm currently waiting on a reply to see what information I will need from you. Once I hear back, I will update this thread.
Please reply back with a Yes if I can email you directly.
I am facing the same now as well. My Garmin is restarting on almost every ride. Anyone found a solution to it?
You can email me directly, yes
I'm facing with the same issue. The unit drops the HR and power data for a few seconds, mid-ride. Also switches off randomly (happens at every 2-3 rides), which is very annoying.
Newest Firmware 9.75, did a reset already, because I had a battery drain issue as well - that one has been solved with it at least. No change with HR + power drop and random switch-offs...
Mine has also being doing this for a few months. It restarts as if the ride has ended and I have to press the start button to keep the ride going. I thought it was a glitch on a route but it happens even without a route. I can patch the missing route and distance by correcting these on Strava but it's very annoying if I am on a climb and using climb pro.
