Hello, I'd like to have another pattern for the saved tracks of may Edge 530. I see no way.
DD.MM.YYYY is not the obvious and simple way to save a file if you would keep track of the generated gpx files. The developers of the GPSMAP66 at least added both variants to save files, even if doubled so....
Any Options to define may own pattern or the desired as pre-configured (YYYY.MM.DD)?
