I have tried reinstalling the map via Garmin Express , however the error still exists on startup.
Any ideas on how to fix this ?
Thanks !
Same problem for me.
Managed to fix by going to navigation on the edge, while having garmin connect app open. The edge then gets you to authorise trailforks, this includes registering while connected to…
1. Install the Garmin Connect App on the phone
2. Connect your device with phone using Garmin Connect App (via Bluetooth)
3. Go to TrailForks app in Garmin Connect app (on your phone), create account and…
Thank you so much ..That worked ... .you are a genius !
I had logged the issue with Garmin and they had absolutely no clue... they are still investigating the issue !
Thanks again !
Managed to fix by going to navigation on the edge, while having garmin connect app open. The edge then gets you to authorise trailforks, this includes registering while connected to the mobile app.
After this it says maps unlocked, and the error message has gone at startup.
I got such notice with 5.31 beta fw after updating the maps via Garmin Express.
Then, I accessed the Edge as USB drive with my laptop. I realized that two trailforks maps with different names were on the Edge. I deleted one of them (certainly by chance the right one). In consequence, no more error notofication occured.
I just got a refurbished device from Garmin as a HW replacement. It is having this error for the trailforks maps
I have tried to update the maps per below and am very confused as to what maps version should be available. I had 2019.20 available on the old one. I have 2019.10 only on the new one. What maps should we have and from where?
Garmin support told me to try removing memory cards. This is an edge 530 and they knew this as they just set it to me as a HW replacement
