Regular crash when near to radio tower
I am experiencing regular crashes when being on the top of the mountain and near to the radio tower.
I attach two activity files. You can see the power up event at 12:09 and 12:19 respectively.
Archiv.zip
    hi,
    had a look at your files with the FitFileRepairTool
    could you repeat the ride without following a course, just free-ride
    my guess is the course is the cause Wink
    happy & safe sporting
  • I did not follow a course. Was wondering about these events too. I suspect they come from segment detection.
    0 Former Member in reply to hcrohland
    thx, good to know about the segments
    learned something today Slight smile
  • dont You get file system error message if you plug into a PC via USB cable ? in Garmin\Debug(ging) folder and its subfolder should be a few txt files (err.log or on different name) . it contains probably the reason of the shutdown, pls share them
    ah, ss i see You have a Mac (only?), which is not showing any error message if there is any issue with the Edge's file system. (if you just pull out the usb cable from Edge and forgot to dismount, its file system could be became corrupted ) But if you have such a shutdown which happens exactly after 12mins +-few secs, it could be memory error (writing data onto bad sector and shutting down), so probably You need to fullformat your device (not quickformat) )
  • I have some errorlogs and ramdumps attached:
    "unit_id":"3997594351",
    "product_name":"Edge 530",
    "software_part_number":"006-B3121-00",
    "ms_since_epoch":1571007420000,
    "system_version":"4.23",
    "build_type":"PRODUCTION",
    "backtrace":"
    Function Address: 0x60455070
       Call Address at Function: 0x604554BE
    Function Address: 0x60361488
       Call Address at Function: 0x603614B2
    Function Address: 0x603BCF9C
       Call Address at Function: 0x603BE0FE
    Function Address: 0x603BF270
       Call Address at Function: 0x603BF368
    Function Address: 0x603C69A2
       Call Address at Function: 0x603C6A74
    Function Address: 0x603C702E
       Call Address at Function: 0x603C70AC
    Function Address: 0x603C79DA
       Call Address at Function: 0x603C7A00
       Call Address at Function: 0x603C7A16
    Function Address: 0x603C7B36
       Call Address at Function: 0x603C7B70
    Function Address: 0x600B7318
       Call Address at Function: 0x600B7A12
    Function Address: 0x6045A090
       Call Address at Function: 0x6045A0B0
    Function Address: 0x6045703C
       Call Address at Function: 0x6045705E
    Function Address: 0x603C0C0C
       Call Address at Function: 0x603C0DB2
    "error_cause":"RTL Trap",
    "proprietary_info":{
        "Commit ID":"83d680b4ddb210d19ed80331d38152929d85374b",
        "Time":"2019-10-14 0:57:0",
        "Ram Dump":"2",
        "ESht PC":"0x602E4B49",
        "ESht SP":"0x621F30B0",
        "Project Specific":"0x621F30B0",
        "CDP_LOG":"05C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605C61FD,605C6225,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605C61FD,605C6225,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,",
        "RTL Error Number":"6E5D800F",
        "Error Message":"62021180,603614B3,0000E040,0001D7B9,013F0834",
        "Task Name":"MMP main",
        "Saved SP":"62020A58",
        "Saved LR":"604554BF",
        "Saved PC":"604554BF",
        "R[0]":"62021180",
        "R[1]":"603614B3",
        "R[2]":"0000E040",
        "R[3]":"0001D7B9",
        "R[4]":"013F0834",
        "R[5]":"00000000",
        "R[6]":"00000000",
        "R[7]":"00000000",
        "R[8]":"00000000",
        "R[9]":"00000000",
        "R[10]":"00000000",
        "R[11]":"00000000",
        "R[12]":"00000000",
        "R[13]":"00000000",
        "R[14]":"00000000",
        "R[15]":"00000000",
        "cpsr":"00000000"
    "ms_since_epoch":1570897131000,
    "system_version":"4.19",
    "backtrace":"
    Function Address: 0x60454F70
       Call Address at Function: 0x604553BE
    Function Address: 0x60361388
       Call Address at Function: 0x603613B2
    Function Address: 0x603BCE9C
       Call Address at Function: 0x603BDFFE
    Function Address: 0x603BF170
       Call Address at Function: 0x603BF268
    Function Address: 0x603C68A2
       Call Address at Function: 0x603C6974
    Function Address: 0x603C6F2E
       Call Address at Function: 0x603C6FAC
    Function Address: 0x603C78DA
       Call Address at Function: 0x603C7900
       Call Address at Function: 0x603C7916
    Function Address: 0x603C7A36
       Call Address at Function: 0x603C7A70
    Function Address: 0x600B72A8
       Call Address at Function: 0x600B79A2
    Function Address: 0x60459F90
       Call Address at Function: 0x60459FB0
    Function Address: 0x60456F3C
       Call Address at Function: 0x60456F5E
    Function Address: 0x603C0B0C
       Call Address at Function: 0x603C0CB2
        "Commit ID":"870ca8e8f577a4a1c3f999a53db7ae8253e2e36e",
        "Time":"2019-10-12 18:18:51",
        "Ram Dump":"1",
        "ESht PC":"0x602E4A45",
        "ESht SP":"0x621F30A8",
        "Project Specific":"0x621F30A8",
        "CDP_LOG":"05C6025,605CDD51,605C5FFD,605C6025,605CDD51,605C5FFD,605C6025,605CDD51,600E1EF1,605CDD51,605C5FFD,605C604D,605CDD51,605CD06D,605CDD51,600E1EF1,605CDD51,605C5FFD,605C6025,605CDD51,605C5FFD,605C6025,605CDD51,605C5FFD,605C6025,605CDD51,605C5FFD,605C6025,605CDD51,605C5FFD,605C6025,605CDD51,600E1EF1,605CDD51,605C5FFD,605C6025,605CDD51,600E1EF1,605CDD51,605C5FFD,605C6025,605CDD51,600E1EF1,605CDD51,605C5FFD,605C6025,605CDD51,600E1EF1,605CDD51,605C5FFD,605C6025,605CDD51,600E1EF1,605E56E1,605E56E1,605E56E1,",
        "Error Message":"62021180,603613B3,0000E040,00018DF9,013F1434",
        "Saved SP":"62020A40",
        "Saved LR":"604553BF",
        "Saved PC":"604553BF",
        "R[0]":"62021180",
        "R[1]":"603613B3",
        "R[2]":"0000E040",
        "R[3]":"00018DF9",
        "R[4]":"013F1434",
        "R[5]":"00000000",
        "R[6]":"00000000",
        "R[7]":"00000000",
        "R[8]":"00000000",
        "R[9]":"00000000",
        "R[10]":"00000000",
        "R[11]":"00000000",
        "R[12]":"00000000",
        "R[13]":"00000000",
        "R[14]":"00000000",
        "R[15]":"00000000",
        "cpsr":"00000000"
    Ramdumps.zip
  • I further checked the filesystem. It is fine.
  • Are you using the Garmin supplied maps or have you loaded some other maps?
    Can you give the map position of the radio tower?
  • I am using openmtbmap plus the garmin provided trailforks map.
    the radio tower is at N49° 24.224' E8° 43.707' or 49.403705, 8.728438 (https://goo.gl/maps/mbHxdQLE1Hds7JkM9)
    It apparently has a very strong signal. In the past I had my phone crash regularily in its vicinity.
  • The crash appears to be associated with map handling and not electrical interference.
  • Ok, I will - relucantly ;-) - switch to the Garmin provided map for a while and see if it still occurs.
