I am experiencing regular crashes when being on the top of the mountain and near to the radio tower.
I attach two activity files. You can see the power up event at 12:09 and 12:19 respectively.
hi,
had a look at your files with the FitFileRepairTool
could you repeat the ride without following a course, just free-ride
my guess is the course is the cause
happy & safe sporting
I did not follow a course. Was wondering about these events too. I suspect they come from segment detection.
dont You get file system error message if you plug into a PC via USB cable ? in Garmin\Debug(ging) folder and its subfolder should be a few txt files (err.log or on different name) . it contains probably the reason of the shutdown, pls share them
ah, ss i see You have a Mac (only?), which is not showing any error message if there is any issue with the Edge's file system. (if you just pull out the usb cable from Edge and forgot to dismount, its file system could be became corrupted ) But if you have such a shutdown which happens exactly after 12mins +-few secs, it could be memory error (writing data onto bad sector and shutting down), so probably You need to fullformat your device (not quickformat) )
I have some errorlogs and ramdumps attached:
[ { "unit_id":"3997594351", "product_name":"Edge 530", "software_part_number":"006-B3121-00", "ms_since_epoch":1571007420000, "system_version":"4.23", "build_type":"PRODUCTION", "backtrace":" Function Address: 0x60455070 Call Address at Function: 0x604554BE Function Address: 0x60361488 Call Address at Function: 0x603614B2 Function Address: 0x603BCF9C Call Address at Function: 0x603BE0FE Function Address: 0x603BF270 Call Address at Function: 0x603BF368 Function Address: 0x603C69A2 Call Address at Function: 0x603C6A74 Function Address: 0x603C702E Call Address at Function: 0x603C70AC Function Address: 0x603C79DA Call Address at Function: 0x603C7A00 Function Address: 0x603C79DA Call Address at Function: 0x603C7A16 Function Address: 0x603C79DA Call Address at Function: 0x603C7A16 Function Address: 0x603C79DA Call Address at Function: 0x603C7A16 Function Address: 0x603C79DA Call Address at Function: 0x603C7A16 Function Address: 0x603C79DA Call Address at Function: 0x603C7A16 Function Address: 0x603C7B36 Call Address at Function: 0x603C7B70 Function Address: 0x600B7318 Call Address at Function: 0x600B7A12 Function Address: 0x6045A090 Call Address at Function: 0x6045A0B0 Function Address: 0x6045703C Call Address at Function: 0x6045705E Function Address: 0x603C0C0C Call Address at Function: 0x603C0DB2 ", "error_cause":"RTL Trap", "proprietary_info":{ "Commit ID":"83d680b4ddb210d19ed80331d38152929d85374b", "Time":"2019-10-14 0:57:0", "Ram Dump":"2", "ESht PC":"0x602E4B49", "ESht SP":"0x621F30B0", "Project Specific":"0x621F30B0", "CDP_LOG":"05C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605C61FD,605C6225,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605C61FD,605C6225,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,605CDF49,605C61FD,605C6225,605CDF49,605C61FD,605C6225,605CDF49,605E58D9,", "RTL Error Number":"6E5D800F", "Error Message":"62021180,603614B3,0000E040,0001D7B9,013F0834", "Task Name":"MMP main", "Saved SP":"62020A58", "Saved LR":"604554BF", "Saved PC":"604554BF", "R[0]":"62021180", "R[1]":"603614B3", "R[2]":"0000E040", "R[3]":"0001D7B9", "R[4]":"013F0834", "R[5]":"00000000", "R[6]":"00000000", "R[7]":"00000000", "R[8]":"00000000", "R[9]":"00000000", "R[10]":"00000000", "R[11]":"00000000", "R[12]":"00000000", "R[13]":"00000000", "R[14]":"00000000", "R[15]":"00000000", "cpsr":"00000000" } } ]
[ { "unit_id":"3997594351", "product_name":"Edge 530", "software_part_number":"006-B3121-00", "ms_since_epoch":1570897131000, "system_version":"4.19", "build_type":"PRODUCTION", "backtrace":" Function Address: 0x60454F70 Call Address at Function: 0x604553BE Function Address: 0x60361388 Call Address at Function: 0x603613B2 Function Address: 0x603BCE9C Call Address at Function: 0x603BDFFE Function Address: 0x603BF170 Call Address at Function: 0x603BF268 Function Address: 0x603C68A2 Call Address at Function: 0x603C6974 Function Address: 0x603C6F2E Call Address at Function: 0x603C6FAC Function Address: 0x603C78DA Call Address at Function: 0x603C7900 Function Address: 0x603C78DA Call Address at Function: 0x603C7916 Function Address: 0x603C78DA Call Address at Function: 0x603C7916 Function Address: 0x603C78DA Call Address at Function: 0x603C7916 Function Address: 0x603C78DA Call Address at Function: 0x603C7916 Function Address: 0x603C78DA Call Address at Function: 0x603C7916 Function Address: 0x603C78DA Call Address at Function: 0x603C7916 Function Address: 0x603C7A36 Call Address at Function: 0x603C7A70 Function Address: 0x600B72A8 Call Address at Function: 0x600B79A2 Function Address: 0x60459F90 Call Address at Function: 0x60459FB0 Function Address: 0x60456F3C Call Address at Function: 0x60456F5E Function Address: 0x603C0B0C Call Address at Function: 0x603C0CB2 ", "error_cause":"RTL Trap", "proprietary_info":{ "Commit ID":"870ca8e8f577a4a1c3f999a53db7ae8253e2e36e", "Time":"2019-10-12 18:18:51", "Ram Dump":"1", "ESht PC":"0x602E4A45", "ESht SP":"0x621F30A8", "Project Specific":"0x621F30A8", "CDP_LOG":"05C6025,605CDD51,605C5FFD,605C6025,605CDD51,605C5FFD,605C6025,605CDD51,600E1EF1,605CDD51,605C5FFD,605C604D,605CDD51,605CD06D,605CDD51,600E1EF1,605CDD51,605C5FFD,605C6025,605CDD51,605C5FFD,605C6025,605CDD51,605C5FFD,605C6025,605CDD51,605C5FFD,605C6025,605CDD51,605C5FFD,605C6025,605CDD51,600E1EF1,605CDD51,605C5FFD,605C6025,605CDD51,600E1EF1,605CDD51,605C5FFD,605C6025,605CDD51,600E1EF1,605CDD51,605C5FFD,605C6025,605CDD51,600E1EF1,605CDD51,605C5FFD,605C6025,605CDD51,600E1EF1,605E56E1,605E56E1,605E56E1,", "RTL Error Number":"6E5D800F", "Error Message":"62021180,603613B3,0000E040,00018DF9,013F1434", "Task Name":"MMP main", "Saved SP":"62020A40", "Saved LR":"604553BF", "Saved PC":"604553BF", "R[0]":"62021180", "R[1]":"603613B3", "R[2]":"0000E040", "R[3]":"00018DF9", "R[4]":"013F1434", "R[5]":"00000000", "R[6]":"00000000", "R[7]":"00000000", "R[8]":"00000000", "R[9]":"00000000", "R[10]":"00000000", "R[11]":"00000000", "R[12]":"00000000", "R[13]":"00000000", "R[14]":"00000000", "R[15]":"00000000", "cpsr":"00000000" } } ]
Are you using the Garmin supplied maps or have you loaded some other maps?
Can you give the map position of the radio tower?
I am using openmtbmap plus the garmin provided trailforks map.
the radio tower is at N49° 24.224' E8° 43.707' or 49.403705, 8.728438 (https://goo.gl/maps/mbHxdQLE1Hds7JkM9)
It apparently has a very strong signal. In the past I had my phone crash regularily in its vicinity.
The crash appears to be associated with map handling and not electrical interference.
Ok, I will - relucantly ;-) - switch to the Garmin provided map for a while and see if it still occurs.
