Updated to version 17.26 and get an estimated battery life of 8 hours 95% battery
Thank you all for your participation in this thread. This is resolved in software version 18.23.
Thank you everyone, I have made a report of this.
I do believe it is not only a calculation issue. The battery seems to drain faster!!! Just lost 10% on a 1h45min ride... more than double of previous software versión! GARMIN FIX THIS ASAP!!!
Same here. Big issue
I recently did a long 322 mile ride over 49hrs and 30min and noticed that the battery drained much quicker than it had previously before updating to v17.26. I also noticed the remaining battery estimates were much lower than they were previously. On a full charge, running battery saver it was estimating 26hrs remaining, without battery saver enabled only 13hrs. Garmin actually sent me a replacement device thinking it was related to my unit specifically. The new device arrived and fresh out the box with a fully charged battery I got the same estimated times as above. This is very disappointing since most of us probably purchased this model specifically because of extended battery life they advertise. Hopefully they can put a patch out to fix this issue quickly, or at the very least give us the option to downgrade to previous firmware versions.
Hello,
I have done more tests with SOLAR 1040, right know I can only tell, that GARMIN KILL battery in this device ! with last updates 10h-12h is maximum, this is disaster - compere previous generation 1030 (25h).
GARMIN you should change immediately, or do cashback program for this device, right know is peace of ***.
Install the IQ data field called Battery Up Down. It writes battery level and discharge rate to the .fit file and you can examine it in Garmin Connect. Maybe it'll provide clues for you. it's neat to see anyway.
How high is your backlight set?
