16.13 Sensor issue Garmin Edge 1040 Solar still present
Hi,
After update to 16.13 bug is still present in my case.
After wake up from sleep I see sensors but when I hit Ride after 10 - 20 secodns sensor are gone :(
Best
Tomek
  • same here, at the moment no problems with sensor connectivities; finger crossed...
  • Garmin! When you, world leadership in sport equipment, will solve this problem or the hands of your engineers grow from "one place (ass)"
  • Just upgraded my 1040 head unit to firmware 17.29, and the Garmin sensors failed to return after the unit had been in sleep mode overnight. I could see the head unit was "searching" for the sensors, which were active, i.e., crankset, wheel and heart rate. I browsed into the head unit, main, sensors, and I tried turning each sensor off and back on, but the head unit would not reacquire the sensor's broadcast.
    After I shutdown and restarted the head unit the sensors came back automatically.
    ANT+ does not "pair, broadcast only. I don't know what type of tags the head unit implements, but a memory issue exists.
  • Hi rmsmith1126, the same for me. Sometimes on wake from sleep it is like you mentioned (I am not sure though if it did also happen for me after a proper boot - I will try to note this, after the next time it happens to me). Sometimes it initially connects and after a few minutes I loose all my sensors and then only a reboot helps (like you mentioned). Roughly every second or third ride this happens.
  • My observation: After waking up the device (1040s) it finds my Di2, Speed Sensor, HR, Rally, Varia RTL 515 very quickly. Once I start moving again, all sensor are gone immediately. Then I need to pause the ride, switch off the device entirely, and reboot (after which I proceed riding with no issues until the next pause & sleep).
    Permission: Yes, please.
    Country: Germany.
