When I try to add a sensor to the 1040 using the ID, the text entry will not allow me to enter the 6th digit of the ant+ ID .
In my case i am trying to an an RTL515
Jay
Jay
Thanks for the Tip. I had no problem with the first 515 doing exactly , but its the second that wont pay ball. The situation is that I ride Audax (Randonneuring) So tomorrow for example I have a 300k (190 miles) ride that has to be completed in 20 hours to get the qualification time. What i do is ride with one 515 and then swap to the other and let the first charge on a battery pack whilst continuing to ride.
I wonder if their is some logic to only support one radar unit in alight network. I think that may be the case. You can pair it as a second radar so will get traffic warnings, but would have to adjust the light pattern manually.
OK lets keep this one clear. There is a definite BUG you can enter enough digits to add an ANTI id manual.
The is a second tread about the problems of adding a second radar unit to the device. I am add my updates to the
https://forums.garmin.com/sports-fitness/cycling/f/edge-1040-series/326813/second-rtl515-does-not-connect-to-light-network
Julian Young thank you for reporting. Garmin is aware of this and has a ticket open.
